Thread: Key fob programming
Results 1 to 20 of 23
  1. #1 Key fob programming
    GT Level Member xxburkettxx07's Avatar
    Topeka, ks
    98gtp won't enter into programming mode for key fob
  2. #2 Re: Key fob programming
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    What have you tried?
  3. #3 Re: Key fob programming
    Topeka, ks
    The programming mode pull mall pgm fuse turn key open door, all it does is start chiming not once but a bunch
  4. #4 Re: Key fob programming
    Aug 2011
    'Merica
    Google search on how to do it. You need to take out the MAP (I believe) fuse to program it.
  5. #5 Re: Key fob programming
    Oct 2012
    Union, OH
    Did you turn the key back to off before opening and closing the door? Did you close the door?
  6. #6 Re: Key fob programming
    Oct 2012
    Union, OH
    He's got the right fuse, I think he's missing the other steps...
  7. #7 Re: Key fob programming
    Aug 2011
    'Merica
    1998-2003 Key Fobs
    Enter the car and close all doors. In the fuse panel, remove the "MALL PGM" fuse. Put your key into the ignition, and turn to "ACC." Turn the key on and off within a second. Open and close the driver's door and listen for the chime that indicates you are in programming mode. Press and hold the LOCK and UNLOCK buttons for 14 seconds, listening for the chime. Wait 14 seconds for the second chime. Repeat this step for all additional remotes, remove the key, replace the fuse, and exit the car. You will have programmed the remotes.
    Read more : http://www.ehow.com/facts_7714654_do...x-key-fob.html
  8. #8 Re: Key fob programming
    Oct 2012
    Union, OH
    lol...same site I used...
  9. #9 Re: Key fob programming
    Aug 2011
    'Merica
    IMPORTANT: Before entering programming mode, have in possession all of the remotes you
    will be useing on the vehicle. Once you program the remote. all previous remotes that were
    programmed will be erased from memory. The other remotes will not be functional until you
    program the them again.
    1. Remove the key from the ignition.
    2. Close all doors.
    3. Remove the "MALL PGM" fuse from the fuse panel. Use the legend on the fuse panel or
    owner's manual to properly locate the "MALL PGM" fuse.
    4. Insert the key into the ignition, and turn to the ACC position.
    5. Turn the key to OFF and then back to ACC within 1 second.
    6. Open and close any vehicle door. A chime will be heard when the system enters into
    programming mode.
    7. Press and hold the remote LOCK and UNLOCK buttons simultaneously for 14 seconds.
    IMPORTANT: After 7 seconds, a chime may be heard confirming successful
    synchronization. It is necessary to wait approximately 14 seconds for a second chime
    that will confirm successful programming.
    8. Repeat step 7 now for each additional remotes to be programmed including any existing
    remotes.
    9. Remove key from ignition.
    10. Install the "MALL PGM" fuse back into the fuse panel and test remote(s).
  10. #10 Re: Key fob programming
    Topeka, ks
    I got all the steps find them on here tried it for an hour I've done it before on my 01gt never had a problem
  11. #11 Re: Key fob programming
    Aug 2011
    'Merica
    Battery issues or ignition issues.......
  12. #12 Re: Key fob programming
    Topeka, ks
    I git the fob from an 03 Buick key fob looks identical, but numbers on back are different, but that shouldn't matter, bc my car won't enter the programming mode
  13. #13 Re: Key fob programming
    if you bought the car with no fob, call a dealer with your vin#. some cars just dont get to have a fob.
  14. #14 Re: Key fob programming
    Topeka, ks
    I have the original changed the battery n it wouldn't work
  15. #15 Re: Key fob programming
    Topeka, ks
    I read something about when you try to enter the programming mode n it keeps chiming, that there is trouble chooses in the bcm, everything works on my car I have no issues
  16. #16 Re: Key fob programming
    also flip both fobs over, theres a part # on the back. if they dont match it wont work, 01 regal fob, may not work on a 98 gp.
    if your fob was working before it maybe fix able by cleaning the contacts on the board and the button pads with rubbing alcohol.
    or it may just need the ground soldered back near the battery.
  17. #17 Re: Key fob programming
    Topeka, ks
    I'll check thanks, I'll keep you posted
  18. #18 Re: Key fob programming
    Topeka, ks
    Sat down in the car at lunch and all a sudden my key fob works wtf lol
  19. #19 Re: Key fob programming
    Oct 2012
    Union, OH
    Magic...lol
  20. #20 Re: Key fob programming
    Topeka, ks
    I know right
  1. 04-08 Key Fob Programming?
    By hammerline81 in forum General Tech Discussion
    Last Post: 09-07-2016, 05:35 PM
  2. Programming a fob
    By Angelo1912 in forum General Tech Discussion
    Last Post: 08-13-2012, 09:57 AM
  3. Key Programming
    By designsquire in forum General Tech Discussion
    Last Post: 07-28-2009, 08:42 PM
  4. Programming
    By Jerime in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2009, 07:10 PM
  5. Programming my Key FOB
    By Keet04GTP in forum General Tech Discussion
    Last Post: 09-06-2008, 12:42 PM
