Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
http://tapatalk.imageshack.com/v2/14...29669cce65.jpg
http://tapatalk.imageshack.com/v2/14...417f003de5.jpg
Trying to clean up the ssei tips. Is there good looking dual tips that work on a Bonneville? 2.0" inlet and I want them to stick out another 2.0" inches.
those tips look exactly like tips from a sunfire GT 2.4L with dual exhaust, im not sure if the year matters but my old one was a 99' and they were the exact same
how does that sound? it make the sc louder?
Sallydoggs
I hope quieter when I get the other side mounted. http://tapatalk.imageshack.com/v2/14...dc7955f073.jpg
nice parts list.
cant wait to hear that intake, looks like it should be a muffler of sorts, but will have to wait and see i guess.
VW scirocco, I'm surprised to see someone makes one with such low fin count.
Sallydoggs
nice parts list.
My buddy ran one on and old caddillac def makes it's own unique sound. It's a really deep intake noise
theaceofspades
The intake sounds good. Actually really good! It's between a stock air box and a open cone.
I hated just the open cone hot air intake, the sound was horrible.
I found good info on VW radiators.
http://tapatalk.imageshack.com/v2/14...0948f88295.jpg
http://tapatalk.imageshack.com/v2/14...8274e64c4f.jpg
I ordered an advance auto brand with low fins per inch count. I also orders without AC.
I have a Spectra Premium CU98 on order.
Great info. Amazon carries just about everything as long as you have a part number.
http://www.amazon.com/Spectra-Premiu...a+Premium+CU98
What are you planning to use as an overflow tank? Also going with a Bosch pump?
I'm going to use tee fitting and clear 3/4" hose. Yes to bosch pump.
Will the radiator come with the sensor hole plugged?
It will likely have a shipping cap on the port, iirc you should be able to get a rubber hose type dinkis cover to delete that port, and a hose clamp.
https://www.nationalpartsdepot.com/s...c-8854-60k.jpg
I've seen people use a short piece of heater hose and plug it with a chrome lug nut or whatevers handy.
