Step 2 - Remove the center console. This is done by removing the screw in the shifter and taking the handle off. It is a Phillips screw. Then put the seats back and remove a bolt on each side of the console. Then put the seats forward and remove the 2 bolts at the back of the console near the floor. Then put the key in and shift the car to L. The console will then come up and out. There are two clips that it must be popped out of. Then put the car back in park and remove the key.
