Thread: How to replace heater core and water pump
Results 1 to 10 of 10
  1. #1 Re: How to replace heater core and water pump
    Akron, Ohio
    heater core is fun.
    remove the console and then start taking every gold colored bolt out of the center section under the dash. once you can see the core, follow the 2 pipes up to the inside of the fire wall, theres a screw holding it up there, then take it out, and replace it.
    if you search around a bit you'll find a few posts covering this job.
    It is not fun. My kids have learned several new swear words. Also, I did read all the posts, but none had enough detail, so I am putting in a bunch of detail. Partly to help other people, but partly to help me so I can put it back together. I took off a bunch of stuff I did not need to, and did not take off some stuff that I was supposed to.
  2. #2 Re: How to replace heater core and water pump
    Akron, Ohio
    Step 5 - remove the black pieces under the dashboard. There are 3 plastic rivets holding these on. Pull out the raised tab and the rivet will come out.
    Now you can actually start at teh heater core.
    Step 6 - remove the outer heater core cover. There is a great post on this on this site. With the seats out can carpet back there is plenty of room, but you have to lay on you bcak and make sure you have a good light source. You need a 1/4 inch wood chisel and nut drive toremove all of the mounting point. There are plastic rivets that you need to scrape off the head with the chisle. Just take it down until it is flush. Now you can pop off the outer cover
    Step 7 same thing for the inner cover. Screws and plastic rivets. There is one that I could not get to without a swivel type extension on my socket.
    Step 8 - remove the heater core by just pulling it out. There is a foam piece behind it. Still not sure what to do with it. It has a piece of paper that if I remove I could stick to the heater core, just like the new one I bought. This is where I am at for now. If ayone has any ideas on the foam piece, and whether the paper goes toward the core or away I would appreciate it.
  3. #3 Re: How to replace heater core and water pump
    Akron, Ohio
    Step 9 - wait for outer heater core cover to come from dealer because you broke it because you did not remove the seats and carpet first time around to get the rear heating duct out.
  1. Bad water pump,wrong water pump? 2002 GTP
    By R STARR in forum Introductions/Noob Questions
    Last Post: 06-03-2013, 06:47 AM
  2. Heater core
    By jase711 in forum General Tech Discussion
    Last Post: 02-18-2013, 01:29 PM
  3. water in heater blower fan or water on passanger floor
    By coolcat2010 in forum How To Write-Ups/Tech Tips
    Last Post: 03-19-2010, 04:20 PM
  4. heater core?
    By CMURDAx in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-14-2009, 02:16 PM
  5. Heater Core
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2008, 08:58 AM
