Thread: Adding HUD and a DIC to your 97-03 GP
Results 1 to 20 of 167
  1. #1 Re: Adding HUD and a DIC to your 97-03 GP
    There wasn't an extra plug in my 97 either. I just followed the link and info from the beginning of this thread/post. It helped a great deal as it listed what wires go where. I had it installed in my car rather quickly. Btw you will need to run an extra wire over to your instrument cluster. What I did is cut off one of the old pins from the old connector from the analog dic, you'll simply slide it back into place on your instrument cluster connector in location C1-F. The wire you need to run from your digital dic is the purple/white wire marked B-10 on the connector from your digital dic harness.
    Snorlax strikes again.
  2. #2 Re: Adding HUD and a DIC to your 97-03 GP
    SE Level Member Seagya's Avatar
    Palm Coast
    I did this mod 2 wekends ago. I used a 1998 GTP DIC into my 2002 GT. The color of the wires did NOT match but i did run them per instructions. And everything works on it except the display never dims. I did the TCS mod where you solder a wire from point a to point b. My TCS light never comes on. BUT thay maybe a blown bulb as every bulb from the GTP was bad.
  1. Adding Performance Shift [*]
    By GeddyLee in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2014, 06:44 PM
  2. Thinking about adding a turbo
    By MS1227 in forum Turbo
    Last Post: 12-13-2008, 04:22 PM
  3. adding gauges
    By keenan00gtp in forum Visual/Body Modifications
    Last Post: 10-12-2008, 11:48 PM
  4. news question about adding performance shift
    By abuckley1290 in forum General Tech Discussion
    Last Post: 07-16-2008, 11:56 PM
  5. Adding acetone to gasoline
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-24-2008, 01:24 PM
