Also, another dumb question: all the how-to's on doing this I've read state that you unbolt the top two mounts, then you either start by doing the bottom motor mount, or the trans mount separately. Wouldn't you need to unbolt ALL of these simultaneously in order to raise the engine/trans, otherwise how is it going to lift up if either the trans is still bolted to its mount, or the motor is still bolted to its bottom mount? I'm just confused because everything I've read says you can do one at a time, re-tightening them as you finish and then move onto the other.
