Thread: adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
Results 1 to 20 of 24
  1. #1 adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    This HOW TO write-up on Aftermarket Radio Installation Kits has been added to the How To Section and can be found HERE
    -Steven-
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
    alhambra, Il
    My first sticky, I am proud of myself. haha.
    Steven Oliver
    GrandPrix Junkie
    Saraland Alabama
    that is only the optional audio too correct? I know my car I made a harness and have retained RAP, but don't have onstar or bose, and I always use the kit on cars that have either (just trying to clarify)
    alhambra, Il
    I am not sure what you are asking, I am sorry, sometimes I dont understand things I read to well. What year was the car you retained rap in? Every car I have done from 97-08 and used the cheap harness Rap has went away. I am just curious, does it have any wierd options or anything rare on it.
    Steven Oliver
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    i think i found a misprint.
    the 97-03's didnt run the chimes, etc thru the radio. the regular 21 pin harness should work fine for these, and retain the RAP, no problem. -- no need to relocate the factory hu in these years. i think you meant to have different years here or this #1 in a different spot?
    adding an aftermarket radio to bose/onstar/monsoon in 97-03 &amp; 04-08 [*] Attached Images
    alhambra, Il
    No it wasn't a misprint, not saying any one person is wrong here, because I could have just not noticed it working, which has been known to happen since I a only human. From what I recall when I replace radios it doesn't retain the rap, but it might be just me recalling the 02-03's that I have done.
    Steven Oliver
    SW Chicago Suburbs
    i dont have access to the factory schematics for anything but my 97, but i looked that one up, and it makes sense to me. -- the RAP is handled completly through the bcm, there is not a RAP feed to the head unit at all --the RAP module tells the bcm to cut power on the switched 12v to the accessories, so there are no extra wires at the hu. (i thought it was this way until the Class II data showed up in the 04's but i dont know about the 02/03's (dont all of the radios between 97-03 interchange? ))
    on edit:
    I did soome more digging, and here's what I verified. (thought was the case, but found info) 97-03 didnt have class II data bus. RAP power was controlled at the bcm/RAP module that cut power to the switched acc leads. (just like taking out key)
    the 04 and up have the class II data that takes place of the switched 12v lead (and controls the RAP)-- when you add an aftermarket hu, you dont get the RAP signal here without the special plug and play adapter that provides the 12v switched + RAP. --- the biggest clue in that the RAP might not work as expected is if you end up running a 12v switched lead to the new aftermarket stereo.
    obviously, s1795so2, you've likely installed more stuff than I, so i havent seen every possible scenario, but it seems that's how it's supposed to work (maybe the RAP module in the 97- 03's go bad??)
    SW Chicago Suburbs
    i see what you're saying, just trying to figure it out in my head-- i dont remember doing anything special in my 97 to retain RAP, but it's there. i dont have the bose system, so i dont have RAP power going to an amp, but the radio stays on. I'll have to look at the wiring diagrams.
  9. #9 Re: adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    GrandPrix Junkie
    Saraland Alabama
    I was thinking the RAp was separate from the radio
  10. #10 Re: adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    SW Chicago Suburbs
    Quote Originally Posted by archemedes View Post
    it is, to a point. it's connected directly to it, but the RAP does keep the radio on with the other accessories
  11. #11 Re: adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    GrandPrix Junkie
    Saraland Alabama
    but if the radio is removed the accessories stay on, was my point
  12. #12 Re: adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    SW Chicago Suburbs
    yeah. the dome lights, etc etc would still be on RAP, just not the HU.
  13. #13 Re: adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    GT Level Member Chleby's Avatar
    Sioux Falls, SD
    when I went to my local shop to get a harness they cheked whether it came through the stereo or not and in my cars case it didn't but the wayit seemed some GPs do and some don't...it must just depend on the options...
    2001 Grand Prix GT...turbo build soon to come
    http://www.cardomain.com/ride/2618949
    Andrew Chleborad....Sioux Falls, SD
  14. #14 Re: adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    GrandPrix Junkie
    Saraland Alabama
    I think the onstar changes it
  15. #15 Re: adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    alhambra, Il
    I am thinking that this is the case: It seems like it does depend on options, and I think toasty and archemedes figured it out. Rap may be retained (sometimes) and if it is the h/u does not stay on, just the accesories. Which most people don't even know or care that the lights are on the rap system too, they just automatically think of radio.
    Wow finally a forum that has good debate and convo in the audio section! I think this is a good sign for me, haha.
    Steven Oliver
  16. #16 Re: adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    SW Chicago Suburbs
    Quote Originally Posted by s1795so2 View Post
    i think we've about got it down, but if you'll excuse me, i'll ramble on a bit :P
    from what i can see, and from the stuff i've done with my other vehicles (in my 97, and i hypothesize thru 03, since they use the same radio) the RAP function is completely separate and on it's own, not tied into the audio system directly, however the RAP does cut power to the HU when it does everything else. there isnt any exra harness to retain RAP on these because it is 'upstream' if you will. so unless there is something broken with the RAP circuit, any aftermarket stereo in these cars SHOULD operate like the factory one with the RAP functionality.
    (note that the radio in these years did NOT control the chime functionality, and 19990-2003 had onstar capability, but were not Class II data linked, so no RAP issue here either.)
    now in 04, everything is different. The Head unit and onstar, and other items, including RAP are controlled through the Class II data bus. (easiest way to note this on any GM vehicle is if it has RDS, then it's on the Class II data bus (or higher, like the new GMLAN/CAN bus... but we'll not get into that) (and they communicate with each other this way) there is no switched 12v lead at the radio. the BCM sends a signal over the data bus to turn off the radio at the RAP time out. The head unit also plays the chimes thru the factory speakers. If you remove the stock head unit, and wire it up directly, you have to add a 12v switched lead-- if you add it from a RAP source, then that's OK, but if you run it from a circuit that is not, then you loose RAP on the head unit. you also loose Onstar because the onstar unit cannot communicate over the class II data line to the aftermarket head unit doesnt have one. the special adapters that are avaialbe (handfull of companies make them) interperet the class II data and feed the onstar info to the head unit in standard audio format, and also gives you the 12v switched lead, controlled by the class II data, which allows you to retain RAP for the aftermarket head unit.
    ok... that's enough rambling for one post
  17. #17 Re: adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    SE Level Member scooz14's Avatar
    West Bloomfield MI
    iirc you can use the pre-outs on your after market head unit to control the factory amp.
    i have never actually tried, but i remember reading that somewhere.
    12.591@108.00 1.95 60'
    329.9hp 400.1tq
    http://www.mccgp.com/member_details.php?mid=95
  18. #18 Re: adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    SW Chicago Suburbs
    Quote Originally Posted by scooz14 View Post
    dunno. probably depends on the factory amp in the car. bose amp, perhaps that's possible-- but you'd have to convert to bare wire to go into the amp anyway. if it's the delco, that one uses speaker level inputs.
  19. #19 Re: adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    alhambra, Il
    I think that is the 04+ amps actually. I just do it the ways I posted and never have any problems, guess I need to try that on an 04+ one day w/o the owner knowing, haha jk. Maybe some local members will come see me at work one day wanting an install done, and they will let me experiment with their car a lil' more than I already have.
    Steven Oliver
  20. #20 Re: adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    Dec 2008
    Syracuse
    Hey guys.. New member here to both the site and to GM vehicles.
    First off I'm going to apologize for bumping a post 11 months old, and let you know that I have searched and searched but I just feel stupid and can't figure out my problem. I see all of these how-to guides and information but I just have no idea.
    First off, It's about my girlfriends 04 Grand Prix. She just got the car from totaling her other car and it is very emotional for her. I thought as a Christmas present I would hook her up with a Alphine deck. Now I understand all of the On-Star/Rap/Door Chime stuff and that you need a controller to keep all of these features but what if you are just interested in the head-unit and that alone? I see in the how-to that you tapped into accesory wire using the $20 harness (part# 70-2003) but could you elaborate? I just don't have the $130+ for a controller. I just need something so she can sing to her crappy music.
    I know I'm a "newb/noob" but bear with me guys and thanks for reading/helping.
    -Nathan
    P.S> Love her car and I've seen some pretty/heard about some pretty nice ones on here.
  1. Adding Performance Shift [*]
    By GeddyLee in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2014, 06:44 PM
  2. Radio is effed up
    By FoSHO99 in forum Audio, Security & Visual Electronics
    Last Post: 04-01-2010, 03:12 AM
  3. questions regarding adding an aftermaket cd player to bose/onstar
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2008, 04:34 AM
  4. Aftermarket headunit install on BOSE system??
    Last Post: 01-05-2008, 03:51 AM
  5. What aftermarket convertor do you run?
    By my97gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-03-2008, 12:20 PM
