Thread: adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #1 Re: adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    SE Level Member Myprixxx's Avatar
    Apr 2008
    Decatur, IL
    yeah the way i did this worked fine (have bose; no onstar) on a 2000 gtp.. i took a qwik connect from walmart, and put that along with a 2 inch wire on the pink wire into the little (black i think) harness that goes into stock radio (pink wire is bose remote) and added a male connector on there, then put a female end on the blue remote for aftermarket radios and plug them in. Amp turns on when my radio turns on. i put a switch cover in myself, goes into the little cubby on drivers side (far left, closest to door) made out of a mudflap that has three switches (1 for strobes in headlights, 2 for my grill lights and 3 for my sub amp remote.. i used one wire from battery into the cubby and split it and then i dont need to use the radio remote for my subs, just cant leave it on and everything works great
    i knew this guy wasn't b/sing.
    michigan people have better stuff to do, like finding jobs or avoiding robbery.
    quoted from noreasonwhyy
    GenV, Full sized I/C, HAI, 3.0 MPS, N* TB
  2. #2 Re: adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    Greensboro, NC
    Just read the how-to. Little update. the 2008 GP uses the gmos-01 not the gmos-04.
  3. #3 Re: adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    SE Level Member ChicagoGXP's Avatar
    Chicago
    Quote Originally Posted by dbinnc View Post
    Little 2010 Update
    Maybe a 2008 without the Monsoon but the amp doesn't have line-level inputs on it with a Monsoon system. Therefore, you need to have RCAs to output to the stock amplifier. I personally just soldered some on to the aftermarket harness and plugged it in.
    I haven't tried to simply wire it from the aftermarket head-unit's speaker levels, but would presume that would be WAY overpowering to the amp's inputs.
  4. #4 Re: adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    SE Level Member neyel8r's Avatar
    DFW TX
    thanks for the how-to & info. might get around to putting in my kenwood stereo one of these months...lol
  1. Adding Performance Shift [*]
    By GeddyLee in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2014, 06:44 PM
  2. Radio is effed up
    By FoSHO99 in forum Audio, Security & Visual Electronics
    Last Post: 04-01-2010, 03:12 AM
  3. questions regarding adding an aftermaket cd player to bose/onstar
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2008, 04:34 AM
  4. Aftermarket headunit install on BOSE system??
    Last Post: 01-05-2008, 03:51 AM
  5. What aftermarket convertor do you run?
    By my97gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-03-2008, 12:20 PM
