Thread: Water in floorboard (Take 2) - The Permanent Fix
Results 1 to 20 of 662
Threaded View
  1. #11 Re: Water in floorboard (Take 2) - The Permanent Fix
    Odessa, MO
    Quote Originally Posted by peegh View Post
    I have a 2003 prix with this problem. I Rtv'ed the strip but saw this write up and decided to replace it. My question to abrasive is. Is there a modification that needs to be done to the new piece to make it work in my car or is the only modification needed done to the cowl only? I will be picking up the new piece tommorrow and would love to get this in as soon as possible. I'm tired of the water in the floorboard and i'm tired of making sure how I park the car so the water doesn't get in. And IMO I would have paid the 15 to have one shipped. I think that it was deserved considering you found the solution to the problem and did the write up. And thanks for the work you did it is appreciated
    Only the little flange on the bottom of the cowl has to be removed. The new water deflector goes right in after that, without any modification to the new piece at all.
    Some earlier models had a piece of plastic that fit down into the rectangle intake opening, right where the cabin air filter should be if we had gotten one from the factory. It has what look like louvers in it and appears to have been an attempt to help funnel air down into the blower motor fan. If the original rubber water deflector falls off, I can see where it would help funnel water right into the fan. Must not have done much, because GM eliminated it in the later years. My wife's 2000 had it and my 2002 did not. That piece of plastic (if anyone has that) also needs to be removed for revised water deflector to fit. It just pulls right out.
  1. Water in Passenger Floorboard [*]
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 08-31-2012, 07:54 PM
  2. Permanent Water spots?
    By GXPimpin in forum Detailing Tips and Tricks
    Last Post: 10-15-2010, 06:15 PM
  3. Little mishap with water....
    By duane9586 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-10-2008, 10:15 AM
  4. Water proof GenV
    By GR8racingfool in forum Visual/Body Modifications
    Last Post: 03-12-2008, 08:27 PM
