Thread: Water in floorboard (Take 2) - The Permanent Fix
Page 15 of 34 FirstFirst ... 5131415161725 ... LastLast
Results 281 to 300 of 662
  1. #281 Re: Water in floorboard (Take 2) - The Permanent Fix
    SE Level Member Leon's Avatar
    Apr 2009
    US
    Hey mind if I get one? Call me for details 302 724 0779 the names Leon
  2. #282 Re: Water in floorboard (Take 2) - The Permanent Fix
    Odessa, MO
    Hey Leon. The GM part is #15794785
  3. #283 Re: Water in floorboard (Take 2) - The Permanent Fix
    morris
    I have a 2002 gt coupe with 73000 miles on it.Has anyone developed this water leakage problem on the 2002?I also have a 2006 sedan?
    Non of mine are leaking?Did GM modify the cowl after 2000?
    Thanks
  4. #284 Re: Water in floorboard (Take 2) - The Permanent Fix
    Portland Oregon
    My 2004 leaked so I'm betting you just lucked out on the not leaking on you 2002.
  5. #285 Re: Water in floorboard (Take 2) - The Permanent Fix
    Apr 2009
    US
    Thx lol oh yeah I'm gonna need a new blower motor resistor. Water fryed mine lol =]
  6. #286 Re: Water in floorboard (Take 2) - The Permanent Fix
    SE Level Member peegh's Avatar
    pittsboro, nc
    I have a 2003 prix with this problem. I Rtv'ed the strip but saw this write up and decided to replace it. My question to abrasive is. Is there a modification that needs to be done to the new piece to make it work in my car or is the only modification needed done to the cowl only? I will be picking up the new piece tommorrow and would love to get this in as soon as possible. I'm tired of the water in the floorboard and i'm tired of making sure how I park the car so the water doesn't get in. And IMO I would have paid the 15 to have one shipped. I think that it was deserved considering you found the solution to the problem and did the write up. And thanks for the work you did it is appreciated
  7. #287 Re: Water in floorboard (Take 2) - The Permanent Fix
    Dec 2008
    Springfield Illinois 62703
    Quote Originally Posted by thompo123 View Post
    Thanks
    I had the issue on my 2002 GTP
    Stage 3 IC | Ported Gen 3 | 3.2 | MACE 1.9 Rockers | N* LQ4 | PRJ Rails | 4 in CAI | No Cat 3 in SLP |SS Headers | 42.5 | 180 T stat |ZZP PCM Custom Tune| Wide Band | Transgo Shift Kit | KYB AGX SSC Springs |
  8. #288 Re: Water in floorboard (Take 2) - The Permanent Fix
    Odessa, MO
    Quote Originally Posted by peegh View Post
    Only the little flange on the bottom of the cowl has to be removed. The new water deflector goes right in after that, without any modification to the new piece at all.
    Some earlier models had a piece of plastic that fit down into the rectangle intake opening, right where the cabin air filter should be if we had gotten one from the factory. It has what look like louvers in it and appears to have been an attempt to help funnel air down into the blower motor fan. If the original rubber water deflector falls off, I can see where it would help funnel water right into the fan. Must not have done much, because GM eliminated it in the later years. My wife's 2000 had it and my 2002 did not. That piece of plastic (if anyone has that) also needs to be removed for revised water deflector to fit. It just pulls right out.
  9. #289 Re: Water in floorboard (Take 2) - The Permanent Fix
    Odessa, MO
    Thanks
    Your 2002 has the old rubber seal that tends to fall off and cause the water in the floorboard issue. I would suggest at least pulling the cowl and gluing it in place BEFORE you have a problem (or replace it with the revised part) just to nip water, and blower motor failure from the water, in the bud. Your 2006 may or may not have the new part already. I have found that 2004-2007 Grand Prixs occasionally have the new one already in place. Most don't, but for some reason it's kinda spotty on those years. 2008+ w-bodies should all have the new deflector already.
  10. #290 Re: Water in floorboard (Take 2) - The Permanent Fix
    pittsboro, nc
    Thanks again for your help. Got the part yesterday and will put it on today
  11. #291 Re: Water in floorboard (Take 2) - The Permanent Fix
    Donating Users dirtmaster88's Avatar
    Sheboygan, WI
    Thanks for this awesome write-up. I've been having problems with a damp/wet floor since i've bought my car 2.5 years ago. Last winter my blower motor started acting up and now it barely even works. Thanks to this post I finally know what the problem is! I do have one additional question though. It appears that my cowl is warped because there is a large gap between the cowl and the windshield that water leaks through. Does anyone know the part number for the cowl? I have a 2004 GTP. Thanks guys. Also I appreciate your generosity Abrasive and Reptile. If I would have seen this sooner I would have definatly had you send me one.
  12. #292 Re: Water in floorboard (Take 2) - The Permanent Fix
    Odessa, MO
    Can a mod please put the part number in the original post? The GM part is #15794785
    I can't edit it because of the amount of pictures. If you could delete the last paragraph also that would be great.
    Thanks!
  13. #293 Re: Water in floorboard (Take 2) - The Permanent Fix
    GT Level Member Black18Ice's Avatar
    Iowa
    Ok so I did this today and the part was under 4 bucks from the dealer...awesome. Then went to install..sucked. I have the one piece cowl and the pass. side wiper would not come off. Decided to quit being dumb and just try it with the wipers still on. Worked great just be careful not to break the cowl. So if you want to save your blood just keep the wipers on and be careful.
  14. #294 Re: Water in floorboard (Take 2) - The Permanent Fix
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    I had the one piece on my GP and replaced it without taking the wipers off. Just set the wipers straight up and be patient.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  15. #295 Re: Water in floorboard (Take 2) - The Permanent Fix
    W. Mass
    Thanks for the write up. It also shows a much easier way to get acorns out of the fan than taking the blower motor out.
  16. #296 Re: Water in floorboard (Take 2) - The Permanent Fix
    SE Level Member Purple Plazma's Avatar
    Nov 2009
    Trevose,PA. (near Philly)
    Glad I found this thread! I just sucked approx 3 quarts of water from the floor in my '98 G.P. Stopped off at the local G.M. dealership just walking distance from my house and asked for the part # listed here. He said."no problem, got one in stock. Your total cost ( I've got a shop account),will be $2.69". . Just gotta install it now. List price was $3.39!
  17. #297 Re: Water in floorboard (Take 2) - The Permanent Fix
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    THANK YOU TO ALL WHOM HAVE POSTED HERE!!!! I picked up the $4.01 deflector yesterday and plan to put in tomorrow. My pass side carpet has been soaked with all the OCT rain we had in MN. I took my GP through the car wash and even had water leaking onto the floormat. I stumbled upon this site via a google search and a few clicks. I have had the 03 GT a little over 3 years and am on my 2nd resistor and fan.
    Looking forward to reading future posts!
    Thanks again!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!1
  18. #298 Re: Water in floorboard (Take 2) - The Permanent Fix
    Nov 2009
    A little late
    Why is the rubber hood seal not replaced and would it be wise to add a little RTV to the edges of the new deflector??
    Thanks!!
  19. #299 Re: Water in floorboard (Take 2) - The Permanent Fix
    GTX Level Member JoelW98GTP's Avatar
    Nov 2009
    Portsmouth, OH
    All you have to do is clean the track in the weather stripping with some sort of solvent like laquer thinner or alcohol and clean the rim on the firewall the same way and RTV the weather stripping back on. Problem solved for $5 for at least 10 years. Genital Motors just forgot to secure the piece of weather stripping to the rim. haha! Whoops 1000000000 times over. Their design is ok but they just FORGOT to glue it down on millions of cars.
    *edit* - When I used to do this kind of work for the public, people would come in and say their car had a leak. Soon as I asked them what kind of car it was and went out to see the 3" of water in the floor board, I'd say "I charge $25 to fix the problem." They would always ask why it was so cheap to fix. I'd say "10 minutes and some glue. That would equal out to like $100 an hour. Want me to raise my price?" HAHA some didn't find that funny, but some did.
    98 GTP - Autolite 104s, wires, 180* t-stat, fwi, catless dp and plog, glasspack res, Reptile tuned PCM, tinted tails.
    91 Toyota MR2 Turbo - 327RWHP 322RWTQ 11.48@122mph
    03 BMW 325i - tint. stock.
  20. #300 Re: Water in floorboard (Take 2) - The Permanent Fix
    Nov 2009
    Sun Prairie, WI
    Oh nice, girlfriend was asking why there was a puddle on her floor the other day and I couldn't figure it out. Gonna order one tomorrow, can't beat that price and looks easy to install.
  1. Water in Passenger Floorboard [*]
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 08-31-2012, 07:54 PM
  2. Permanent Water spots?
    By GXPimpin in forum Detailing Tips and Tricks
    Last Post: 10-15-2010, 06:15 PM
  3. Little mishap with water....
    By duane9586 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-10-2008, 10:15 AM
  4. Water proof GenV
    By GR8racingfool in forum Visual/Body Modifications
    Last Post: 03-12-2008, 08:27 PM
