Thread: Water in floorboard (Take 2) - The Permanent Fix
Page 30 of 34 FirstFirst ... 202829303132 ... LastLast
Results 581 to 600 of 662
  1. #581 Re: Water in floorboard (Take 2) - The Permanent Fix
    Donating Users
    USA
    When the washer hose clip on the cowl snapped off in my hand, I thought I was dealing with a very rigid piece of plastic, so I figured I had to take the entire cowl off to make sure it wouldn't break in the cold too. So the wiper arms had to be removed, and it was off the chart tough to even get them to budge. Still looking for an easier way to get them off. Maybe temporarily disable the arm spring and then pull? Might work...
    Black 1998 GT Coupe
  2. #582 Re: Water in floorboard (Take 2) - The Permanent Fix
    Grand Rapids, MI
    meh, I don't see the whole thing snapping in half, just gotta fit your hand under there more or less. 01+ is nice because it's in two pieces.
  3. #583 Re: Water in floorboard (Take 2) - The Permanent Fix
    Quote Originally Posted by michaelb721 View Post
    a small 2 jaw puller works best. a claw hammer also works or a pry bar. just watch you dont crack the windshield.
  4. #584 Re: Water in floorboard (Take 2) - The Permanent Fix
    Jan 2014
    Port Orchard, WA
    So, as I understand from skimming a few pages this is for the passenger side. I discovered the drivers side floor to be very wet when I was unplugging the relay box thing. Any suggestions or maybe a link to the right thread?
  5. #585 Re: Water in floorboard (Take 2) - The Permanent Fix
    Quote Originally Posted by BillPendleton View Post
    that sounds like the heater core is leaking. see if it smells sweet, or if your coolant is low in the rad.
    you can also pull the carpet up and try to trace the leak.
  6. #586 Re: Water in floorboard (Take 2) - The Permanent Fix
    Jan 2014
    Port Orchard, WA
    Heater core is on the drivers side?
  7. #587 Re: Water in floorboard (Take 2) - The Permanent Fix
    the heater core is dead center of the dash (in front of the console ) and can leak from either side to the floor and soak the carpet.
  8. #588 Re: Water in floorboard (Take 2) - The Permanent Fix
    Jan 2014
    Port Orchard, WA
    It isn't coolant. It's water for sure. I can see water on the kick panel. My first guess is the sunroof.
  9. #589 Re: Water in floorboard (Take 2) - The Permanent Fix
    id run a hose over the car, start low, like the wiper cowl, the worj higher up the windshield then to the roof.
    windshield's have been know to rust out around the frame and leak.
  10. #590 Re: Water in floorboard (Take 2) - The Permanent Fix
    Jan 2014
    Port Orchard, WA
    I give that that try, thank you. Has there been a known issue about the weather stripping around the door? I doubt thats where the leak is coming from but I figured I could ask.
  11. #591 Re: Water in floorboard (Take 2) - The Permanent Fix
    Jan 2014
    Port Orchard, WA
    I found the leak. I took a picture but I can't figure out how to upload it with my phone. It's coming in right by the mirror. There is a small indentation in the door and I think its getting in there. I'm going to get a new door seal and see if that fixes it.
  12. #592 Re: Water in floorboard (Take 2) - The Permanent Fix
    Feb 2014
    Decatur, IL
    Hey all...new to the forum as well as a 2004 GT2. Definitely have this water issue. Went through the car wash and ended up with a floorboard full of water. I need to know if the GM part 15794785 mentioned at the beginning of this thread will fit on the 2004 Grand Prix. Thanks.
  13. #593 Re: Water in floorboard (Take 2) - The Permanent Fix
    Yup
    04 Comp G.
  14. #594 Re: Water in floorboard (Take 2) - The Permanent Fix
    Feb 2014
    Decatur, IL
    Yup
    Thanks.
  15. #595 Water in floorboard (Take 2) - The Permanent Fix
    No problem
    04 Comp G.
  16. #596 Re: Water in floorboard (Take 2) - The Permanent Fix
    Jul 2010
    Coquitlam,BC,Canada
    Did a little digging. Part #15794785 is designed for:
    06-07 Monte Carlo
    04-08 Grand Prix
    It will also fit:
    97-03 Grand Prix
    00-05 Monte Carlo
    May fit others, but there is no info to confirm.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  17. #597 Re: Water in floorboard (Take 2) - The Permanent Fix
    Feb 2014
    Decatur, IL
    Well ended up getting this from a local dealer who had it in stock. Cost was a whopping $4.69 including tax...lol. Took virtually no time to install in my 2004 GP. Thanks for the write up.
  18. #598 Re: Water in floorboard (Take 2) - The Permanent Fix
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    I found them 2.99 no tax and says 0 on shipping and handling
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
  19. #599 Re: Water in floorboard (Take 2) - The Permanent Fix
    Jul 2010
    Philly
    Got the deflector coming from GMparts direct. Also a Buick cabin air filter, they both can be installed at the same time right?
  20. #600 Re: Water in floorboard (Take 2) - The Permanent Fix
    Jul 2010
    Yepp
  1. Water in Passenger Floorboard [*]
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 08-31-2012, 07:54 PM
  2. Permanent Water spots?
    By GXPimpin in forum Detailing Tips and Tricks
    Last Post: 10-15-2010, 06:15 PM
  3. Little mishap with water....
    By duane9586 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-10-2008, 10:15 AM
  4. Water proof GenV
    By GR8racingfool in forum Visual/Body Modifications
    Last Post: 03-12-2008, 08:27 PM
