Thread: Water in floorboard (Take 2) - The Permanent Fix
Page 26 of 34 FirstFirst ... 162425262728 ... LastLast
Results 501 to 520 of 662
  1. #501 Re: Water in floorboard (Take 2) - The Permanent Fix
    Jul 2010
    Coquitlam,BC,Canada
    Pairsnpaint,
    Go back and look at my posts #460, 461 and 465. I had a good 1-2" of water in my passenger floor after getting a new windshield installed. Ended up being a bad install.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  2. #502 Re: Water in floorboard (Take 2) - The Permanent Fix
    SE Level Member Pairsnpaint's Avatar
    Ocala, FL
    I've inspected the weatherstripping around the door opening and it looks fine. The water is definitly dripping from up under the dash. Are there any other openings directly to the outside other than the blower motor opening? The leak occurs when the car is parked during a rainstorm (as well as when driving) so it's not a "splash-in" situation. I'd rather not have to remove the seat and lay down in the car while it's raining to locate it.
    Hal
    Ocala, FL
    2002 GTP Coupe - 2016 Chevy Equinox
  3. #503 Re: Water in floorboard (Take 2) - The Permanent Fix
    id run a hose from the roof down the windshield, and get in and under the dash to if you can see where its coming from.
    or you can flow the hose low, just on the cowl, area and see if it leaks first, then hit the windshield.
  4. #504 Re: Water in floorboard (Take 2) - The Permanent Fix
    Aug 2012
    florida
    Put some sealer on edge of cowel and tape to hold in place
  5. #505 Re: Water in floorboard (Take 2) - The Permanent Fix
    London Ont, Canada
    I can't believe no one ever try's on replicate rain in a controlled way. Common peeps.
  6. #506 Re: Water in floorboard (Take 2) - The Permanent Fix
    GTP Level Member Lishap's Avatar
    Jan 2012
    New York
    So will this part fit on the 2004+ GP's? went through practically all the pages and couldn't find a definitive answer.
  7. #507 Re: Water in floorboard (Take 2) - The Permanent Fix
    Nov 2012
    Madison
    Quote Originally Posted by Lishap View Post
    YES..Just did it on my 2004compg..replace your cabin filter while you do this
  8. #508 Re: Water in floorboard (Take 2) - The Permanent Fix
    Ocala, FL
    Thanks, Chris. I believe that it's a bad glass install on my car as well. Unfortuneately, it's been too long for me to take it back now. (here in So Fla, we can go months without rain, then it never ends). I may try to see if they will do anything, but I doubt it.
    Hal
    Ocala, FL
  9. #509 Re: Water in floorboard (Take 2) - The Permanent Fix
    Jan 2009
    Tallahassee, FL
    Quote Originally Posted by Pairsnpaint View Post
    Same way up here, Summer is constant and the winter is nothing, at least more than down there.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  10. #510 Re: Water in floorboard (Take 2) - The Permanent Fix
    GTP Level Member joe0813's Avatar
    Boston, MA
    doing this tomorrow.... my pass floor is soaked
  11. #511 Re: Water in floorboard (Take 2) - The Permanent Fix
    Aug 2012
    florida
    2004 gp gt works great
  12. #512 Re: Water in floorboard (Take 2) - The Permanent Fix
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    i see people were buying these from the OP. But i see a GM Part #, you get the same part from the GM dealerships?
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  13. #513 Re: Water in floorboard (Take 2) - The Permanent Fix
    Nov 2012
    Madison
    I bought mine online with the same part# for 3.98 plus shipping. I just ordered a cabin filter and headlight brackets at the same time to offset shipping.
  14. #514 Re: Water in floorboard (Take 2) - The Permanent Fix
    Mar 2012
    Dallas
    online where?
  15. #515 Re: Water in floorboard (Take 2) - The Permanent Fix
    call you local chevy place and give them the part number and tell them to order it, i got mine shipped over night and the price of the part for like $2.60 something
    SMGPFC Member #10
  16. #516 Re: Water in floorboard (Take 2) - The Permanent Fix
    Nov 2011
    NY
  17. #517 Re: Water in floorboard (Take 2) - The Permanent Fix
    $12 for shipping, makes it not worth it really when the dealer sells it for less then 14 bucks.
    $12 for shipping is crazy. Call local Chevy dealer give then the p/n and have it ordered. It would usually run a few buck more but you avoid those shipping cost and there good at getting it quickly usually mines gets the stuff the next day.
    04 Comp G.
  19. #519 Re: Water in floorboard (Take 2) - The Permanent Fix
    GT Level Member WolvesSoulZ's Avatar
    Québec
    Went at my local dealer last autumn when I noticed wet floorboard (Well the next day it was an ice rink) Went at my local stealership and got it for 7$, was really surprised at it, considering, for example, that an SE front lip is 600$ with the taxes and that a oil pan bolt is 12$!
    But it fixed my problem, albeit that it costed me hundred of squids to fix all issues it caused (Blower motor froze, resistor blew.) But months later, everything still works, but I'm stuck with some ice.
    Overall, best 7$ I spent on my Comp-G.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  20. #520 Re: Water in floorboard (Take 2) - The Permanent Fix
    Oct 2011
    Canada
    04 compg, worked for me. I had a decent amount of water from the front to the back passenger side. Now not a drop.
  1. Water in Passenger Floorboard [*]
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 08-31-2012, 07:54 PM
  2. Permanent Water spots?
    By GXPimpin in forum Detailing Tips and Tricks
    Last Post: 10-15-2010, 06:15 PM
  3. Little mishap with water....
    By duane9586 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-10-2008, 10:15 AM
  4. Water proof GenV
    By GR8racingfool in forum Visual/Body Modifications
    Last Post: 03-12-2008, 08:27 PM
