Thread: how-to: diy aux input for 04+ xm equipped cars
Page 6 of 7 FirstFirst ... 4567 LastLast
Results 101 to 120 of 140
  1. #101 Re: how-to: diy aux input for 04+ xm equipped cars
    gardner,mass
    Quote Originally Posted by marines542 View Post
    I have a moo soon system with it connected to it...did u now read the post before urs I posted
    Sent from my DROID RAZR using Tapatalk 2
    thanks but i found a pretty much free solution to this once i start on it i might write up a little guide for it
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Someone please lock this thread. Jeezus
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  3. #103 Re: how-to: diy aux input for 04+ xm equipped cars
    Yoga city
    why lock this thread?
    Oct 2011
    MI
    all the info you could ever need is here. Sticky and lock it.
  5. #105 Re: how-to: diy aux input for 04+ xm equipped cars
    London Ont, Canada
    How to's shouldn't be full of jibber jabber.
  6. #106 Re: how-to: diy aux input for 04+ xm equipped cars
    SE Level Member Ruben A Del Bosque's Avatar
    Nov 2012
    Texas
    i have an aux option button on my radio but its not xm radio or disc changer is that a superfluous button or is there a way i can tap into it.
    My name is Chobies and i approve this message.
  7. #107 Re: how-to: diy aux input for 04+ xm equipped cars
    Yoga city
    sorry but with out any other module attached ie changer, xm module, that button is useless.
  8. #108 Re: how-to: diy aux input for 04+ xm equipped cars
    I live here. DirtDog's Avatar
    Jun 2012
    if you look onto the back of you stock radio see if it has the 12 pin connector. If it does than you can still install an auxillary adapter that works great. I use it in my car and so much cheaper and easier of an option compared to cutting wires and doing rewiring.
  9. #109 Re: how-to: diy aux input for 04+ xm equipped cars
    Nov 2012
    Texas
    sweet, thanks. I will have to check that out. where can I find the adapter . ?
  10. #110 Re: how-to: diy aux input for 04+ xm equipped cars
    Jun 2012
    hey i just wanna throw this out there for any 04 plus grand prix owners. theres a 30 dollar fix for installing a aux input into your cars. If you have xm radio or any slave unit in your car not counting the 6 disc in dash cd changer there is a kit made by pac audio that is 30 bucks on ebay. Its super easy to install and alot more convenient. There is no interference in it like there is in fm modulators or anything. The exact model for it is AAI-GM12.
    I posted this a month ago. This adapter will only work if you have a 12 pin connector in the back of your radio and a slave unit with your radio. I recommend pulling your radio out first and looking before ordering. If your in doubt if it will work or not take a picture of the back of your radio and post it on here. Also do you have xm radio, and external cd changer, or any other external operating things hooked up to your radio.
  11. #111 Re: how-to: diy aux input for 04+ xm equipped cars
    Dec 2012
    Florida
    Thanks for the writeup. I was able to tap into these wires up behind the factory radio. Same colors. Headunit is very easy to take out, so I found that easier than running the AUX cable through the car. If you use a 3.5mm audio jack, you can just splice the jack inline and have both AUX and working XM radio btw. Just unplug the cable from the jack and XM radio will resume.
    Quote Originally Posted by sirricealot View Post
    On the diagram it shows audio common is pin 10(tan). But you keep saying ground which is 9(black).
    Agreed. Even in the OP, you said we'll be using Pin 10 (tan) as the audio ground. But two pictures later you say to connect the negatives to black/white (electrical ground). THIS WILL WORK. However it gave me some electrical noise through the speakers only when no audio was playing. Playing even a silent track made the noise go away, oddly enough, so it's really not that big of a deal. I was pressed for time and didn't have the opportunity to try out the tan wire, but my guess is that it'll eliminate the electrical noise altogether.
  12. #112 Re: how-to: diy aux input for 04+ xm equipped cars
    Nov 2012
    Madison
    Quote Originally Posted by firebirdude View Post
    I was wondering about that little discrepancy myself. Anybody out there use the tan wire for said voodoo
  13. #113 Re: how-to: diy aux input for 04+ xm equipped cars
    Yoga city
    audio commom= audio ground, whats so hard to under stand common=negative.
  14. #114 Re: how-to: diy aux input for 04+ xm equipped cars
    Nov 2012
    Madison
    Quote Originally Posted by JTeske88 View Post
    not a damn thing
  15. #115 Re: how-to: diy aux input for 04+ xm equipped cars
    Yoga city
    So why ask the question then, I did this on my first try with no help. So can you sobs
  16. #116 Re: how-to: diy aux input for 04+ xm equipped cars
    Nov 2012
    Madison
    nice.. it was jus the black and tan thing ..no big fn deal....its a good D.I.Y. for pennies....the kind we all like!
  17. #117 Re: how-to: diy aux input for 04+ xm equipped cars
    Yoga city
    thank you sir yeah its pretty easy stuff
  18. #118 Re: how-to: diy aux input for 04+ xm equipped cars
    Dec 2012
    Florida
    I simply pointed out that you told people to use two different wires. That's all. I don't care if one is a ground while the other gives you free cupcakes. I simply pointed out the discrepancy. Don't get all butt hurt because your discrepancy confuses someone who may not be as electrically inclined as you. If you don't want to help people, then don't make the walkthrough. I said thanks, but maybe now I'm starting to regret it...
  19. #119 Re: how-to: diy aux input for 04+ xm equipped cars
    Yoga city
    look at the diagram and tell me what it says? blk/tan only combo of those colors there, when i did this original it was done on a corvette, different diagrams, so im sorry for helping you. Besides the point you have a total of 2 post, you joined for my write up or your a troll, get out ma thread
  20. #120 Re: how-to: diy aux input for 04+ xm equipped cars
    Feb 2009
    NE
    does anyone have a solution for the non -XM 6 disk with On Star input? I have searched high and low, gave up and bought a Scotche FM modulator that goes inline with the antenna cable. It worked for a week, now works for 10-15 mins, cuts out. My problem is the door chimes, etc come through the speakers so if I replace the head unit I loose all the headlight alarms, etc.
  1. using XM radio 2004 Grand Prix? (not equipped)
    By Wanted in forum Audio, Security & Visual Electronics
    Last Post: 03-27-2011, 08:50 PM
  2. need some input input input.(short circuit)
    By IR II IP IDEATH in forum 5.3L V8 (LS4)
    Last Post: 02-17-2010, 03:23 AM
  3. Could a small valve cover leak cause a loss of boost on a PCV equipped vehicle?
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2009, 11:57 AM
  4. Tap Shifters on a car not factory equipped?
    By sickofsoyo in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-03-2009, 05:25 PM
  5. New User equipped with a GXP!
    By Cableguy in forum Introductions/Noob Questions
    Last Post: 10-13-2008, 06:02 PM
