Thread: HOW TO: Solid Mounts
Page 3 of 3 FirstFirst 123
Results 41 to 59 of 59
  1. #41 Re: HOW TO: Solid Mounts
    Kemmerer, Wyoming
    when I filled my engine mount with polyurethane, I just kept filling until it oozed out the holes. if I was going to tap the holes, I would drill the holes out so I could use my 3/8's npt tap, and make sure the plugs used are in there flush so the mount will sit flat.
  2. #42 Re: HOW TO: Solid Mounts
    GT Level Member Brammer's Avatar
    Feb 2009
    Roanoke, VA
    When you say it oozed out the holes, are you referring to the two that I need to drill? The step with the missing picture I quoted talks about a hole on the bottom of the mount?
  3. #43 Re: HOW TO: Solid Mounts
    Kemmerer, Wyoming
    I have an engine mount that I filled with polyurethane but never installed because I ended up picking up a zzp poly mount. I can take some more pictures and post them later, or I can just sell the mount to you.
  4. #44 Re: HOW TO: Solid Mounts
  5. #45 Re: HOW TO: Solid Mounts
    Kemmerer, Wyoming
    first one works, but not second
  6. #46 Re: HOW TO: Solid Mounts
    second one is worthless any ways. its just a pic of the mounts done. i can still see it tho. wonder why some can others cant?
  7. #47 Re: HOW TO: Solid Mounts
    Jul 2010
    Coquitlam,BC,Canada
    Same here. Can see the first, not the second. PB is retarded now. Last night I was looking at a members page for some reference pics; I could view all pics in their index, but when I clicked on them, I could see the first 5 and not the rest. Tried a few more times with the same results so gave up. Today, I do the exact same thing, and can view all the pics. .
    I suspect they are doing this on purpose, as well as the 17 ads that pop-up and start at the same time.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #48 Re: HOW TO: Solid Mounts
    Feb 2009
    Roanoke, VA
    I can't see either, they both give an error about updating your account for third party hosting.
  9. #49 Re: HOW TO: Solid Mounts
    right click the busted pic, then open in new tab, seems dumb but it works for me every time, might have to do it 3 times.
  10. #50 Re: HOW TO: Solid Mounts
    Jul 2010
    Coquitlam,BC,Canada
    I'm sure I tried this before with no luck, but I just tried it and it worked, first time.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  11. #51 Re: HOW TO: Solid Mounts
    hangover park IL
    Yeah I'm pretty pissed that most of my s*** is now dysfunctional
    ~James~ Psychotic Gearhead
  12. #52 Re: HOW TO: Solid Mounts
    Feb 2009
    Roanoke, VA
    Thanks everyone! My mount I grabbed from Advance Auto I was unsure if it was hydraulic or not, and couldn't hear any fluid. The sales rep said since it was cheap compared to the AC Delco one that it was most definitely solid. I drilled the two holes last night and surprise surprise it was full of fluid. I drained most of it, will try to flush it with brake fluid today. I see that the Loctite PL Premium Construction Adhesive has been suggested a few times? Is this a good and viable solution or would I be better off with the more expensive Window Weld stuff from 3M?
  13. #53 Re: HOW TO: Solid Mounts
    Kemmerer, Wyoming
    I don't think it matters, it all dries hard. it might be a good idea to let it dry longer than it needs just so you know it will adhere better when you inject the adhesive.
  14. #54 Re: HOW TO: Solid Mounts
    Feb 2009
    Roanoke, VA
    Dry longer than it needs, meaning the brake cleaner or the adhesive?
  15. #55 Re: HOW TO: Solid Mounts
    Kemmerer, Wyoming
    initially I meant to let the mount dry of all the hydraulic fluid inside, but now that I think about it, I would let both dry for a good amount of time
  16. #56 Re: HOW TO: Solid Mounts
    i blew mine dry with compressed air, they were some what dry, then i let them sit for almost a week to cure after filling them.
  17. #57 Re: HOW TO: Solid Mounts
    Feb 2009
    Roanoke, VA
    Got them all cleaned out and let them dry for a good while out in the sun, and then filled it with Loctite PL Premium Construction Adhesive Polyurethane formula. I got it so full the bottom side has rubber pressed against the hole in the metal bracket.
  18. #58 Re: HOW TO: Solid Mounts
    GTP Level Member
    Jun 2016
    Cleveland ohio
    ANCHOR 2796SR Info
    Front; SOLID RUBBER
    Choose:
    [Regular Inventory] (Only 5 Remaining) ($14.19)
    $14.19
    PIONEER 602796
    Front; SOLID
    $17.99
    all the ones I bought from here are solid. I had the same issue at autozone. saying it was solid but it wasn't.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  19. #59 Re: HOW TO: Solid Mounts
    GTP Level Member buickman104's Avatar
    NYC
    Well, my mounts are shot so I will be giving this a try next!
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  1. Solid steel dog bone motor mounts
    By monsterjam5000 in forum General Tech Discussion
    Last Post: 10-19-2010, 08:32 PM
  2. How solid is the 3.1L
    By Lvgrandprix2003 in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-11-2010, 05:33 PM
  3. Autozone SOLID engine and trans mounts
    By Abrasive in forum Shops and Community Heroes
    Last Post: 08-17-2009, 08:19 PM
  4. Napa solid rubber mounts part #s?
    By blown98gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2009, 08:21 PM
