Thread: HOW TO: Solid Mounts
Results 21 to 40 of 59
  1. #21 Re: HOW TO: Solid Mounts
    Put some crap in there.
    Just a note: I have the DEA solid mounts, the engine mount seems VERY solid yet there still is a cavity beneath the main section of rubber and the bottom metal "cap".
    Its all filled now, going to wait a week or two. Most of these products claim a one week to fully cure.
    I'm sure they dont count on their product being crammed into a 2x3x1" thick block though.
  2. #22 Re: HOW TO: Solid Mounts
    Minnesota
    I forgot to revise this to the fact that I wouldn't use RTV. Some people may be able to get enough in there to make it solid enough but mine depressed.
    EDIT- Fixed.
  3. #23 Re: HOW TO: Solid Mounts
    I'm really liking how this Lepage PL Premium is hardening.
    Cheap too.
  4. #24 Re: HOW TO: Solid Mounts
    gardner,mass
    This deserves more attention. Cheap/nice little mod. Did this cus the mounts i got from my store by anchor blew out in a month. Cost me 12 bucks each and i used 1 1/2 tubes of 3m window weld from my store. So far much better ride.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  5. #25 Re: HOW TO: Solid Mounts
    Nov 2014
    BFE,Ohio
    Any updates on people who did this how are they holding up
    Did my post confuse you? BLAME AUTOCORRECT!
  6. #26 Re: HOW TO: Solid Mounts
    they work great, ill trade ya mine for new hydraulic mounts. lol they do vibrate. and i upped my in gear idle to like 825 or so iirc.
  7. #27 Re: HOW TO: Solid Mounts
    Nov 2014
    BFE,Ohio
    Is it alot more vibes at cruise or only at idle
  8. #28 Re: HOW TO: Solid Mounts
    mostly at idle. you cant see out the side or rear view mirrors lol
  9. #29 Re: HOW TO: Solid Mounts
    Nov 2014
    BFE,Ohio
    Oh and one last question what size holes are you guys drilling thanks
  10. #30 Re: HOW TO: Solid Mounts
    little holes, but big enough to stuff a calking gun tip inside it.
    a air compressor helps to blow out the fluid inside the mount.
  11. #31 Re: HOW TO: Solid Mounts
    Nov 2014
    BFE,Ohio
    I lied I have another question received my mounts today and went to look at pics on where drill again.
    And noticed none for the trans mount should drill up top by the bolts? On the side or bottom? I just didn't want to drill the wrong spot
    Also I'm glad my engine mount was a solid one lol
  12. #32 Re: HOW TO: Solid Mounts
    Kemmerer, Wyoming
    I used this stuff and ran out, don't have anymore, and no one sells it local. should I worry about not filling it to the top? it was coming out the bottom, and wouldn't fill up to the top.
    and for people who use this stuff to, wear gloves, it will make a big mess and won't wash off your hands.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
  13. #33 Re: HOW TO: Solid Mounts
    Nov 2011
    NY
    I think and "poly" sealant would work fine... Locktite has some
    my my thought was always whether to fill all at once, or do it in stages, so to allow the sealant to set, then add another layer, until filled. That would make it nice and solid for sure.
  14. #34 Re: HOW TO: Solid Mounts
    Kemmerer, Wyoming
    Quote Originally Posted by coolone View Post
    this 3M stuff set's up reasonably fast, I had some push out all the holes in the bottom half of the mount, I just couldn't get any to push out the top holes that I drilled. the cure time is advertised as 24 hours, I'll probably let it set up for a week and then install. I will check around for some loctite poly sealant, I'm sure the local parts store will have something like that, I'm just going to put a good coating on the outside and in the middle between the two studs on top and call it good. hopefully the extra vibration doesn't jar any of my wife's teeth fillings out.
  15. #35 Re: HOW TO: Solid Mounts
    thats what i used loctight polyurethane caulking. let it set up for a few days, its rock hard and still very solid. it does add some vibrations in gear at idle.
  16. #36 Re: HOW TO: Solid Mounts
    hangover park IL
    I'm glad this stuff is finally getting used by you folks.
    My original shpiel is here: http://www.thechicagogarage.com/foru...tml#post934054
    Remember letting the 3m tubes sit in a bucket of really hot water will make it easier to pump through the caulk gun
    ~James~ Psychotic Gearhead
  17. #37 Re: HOW TO: Solid Mounts
    Kemmerer, Wyoming
    Quote Originally Posted by Turbocharged400sbc View Post
    that hot water tip would have been useful knowledge yesterday, probably would not have made such a mess if it had come out of the tube easier.
  18. #38 Re: HOW TO: Solid Mounts
    hangover park IL
  19. #39 Re: HOW TO: Solid Mounts
    Kemmerer, Wyoming
    I found this stuff at a store called Bomgaars.
    http://www.loctiteproducts.com/p/pl_...n-Adhesive.htm
  20. #40 Re: HOW TO: Solid Mounts
    GT Level Member Brammer's Avatar
    Feb 2009
    Roanoke, VA
    Does anyone happen to have the picture associated with this step :
    "You also need to fill the bottom of the mount. This can be done by taping or plugging the hole shown in the picture and filling it up (from the middle) untill you seem in coming out of the other holes (on the sides) like this:"
    I have a new "solid" mount I'll drill and check and if I need ti fill it I'd like to know more about what I need to do and make sure I get it right.
  1. Solid steel dog bone motor mounts
    By monsterjam5000 in forum General Tech Discussion
    Last Post: 10-19-2010, 08:32 PM
  2. How solid is the 3.1L
    By Lvgrandprix2003 in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-11-2010, 05:33 PM
  3. Autozone SOLID engine and trans mounts
    By Abrasive in forum Shops and Community Heroes
    Last Post: 08-17-2009, 08:19 PM
  4. Napa solid rubber mounts part #s?
    By blown98gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2009, 08:21 PM
