Thread: Squeeze's How to "clear lensed GP tails"
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 Squeeze's How to "clear lensed GP tails"
    GT Level Member squeeze's Avatar
    Norman, OK
    Alright everyone here is the write up youve all been patiently waiting for!
    *First off i have to give credit to the people who gave me the start up idea for this. Would be Bio off of here and Houdini off of another GP forum. these two showed me how to cut, remove, and lights to use (Houdini).*
    Ok now for the fun stuff!
    *Stuff you will need:
    Hammer
    Flat Head screwdriver
    JB weld(i used the quik dry stuff)
    Silicone
    Ceiling light lense(go to home depo or Lowes)
    Paper
    Sharpie
    Drill
    Dremel with a REINFORCED cutting wheel(if you dont get this specific wheel it will break off and shoot everywhere and wont work!!)
    Safety Glasses
    Lights(whether they be red bulbs or LEDs)
    5/8"s bolt(2) and 5/8"s washer(2) and 5/8"s nuts(2)
    and last but not least PATIENCE lol
    Ok so step 1, you got your stock tail, take it out and take the shroud on the top of it off w/ a phillips.
    Step2) take your dremel and your safety glasses put on and cut around the back like i did here in this pic. Now the plastic will melt and u might have to re cut certain areas but you will know when u have to.
    Step3)Once you have removed the backing from the Light, get your flat head ready and hammer. Youll want to break the red reflector in large pieces. So in order to do that, put your flathead in the middle and give it a few hits with the hammer, not too hard or youll hit the clear lense, but a few test whacks will let you know the strength youll need to use to break it.
    here is the backing removed:
    Step4) After you have removed all the big pieces of Red reflector out of the lens, peice them together somewhere else. Your going to make a rough template of the red lens with paper
    here it is pieced together:
    Here is the paper template, just put it on top of the red reflector and just make a rough trace w/a sharpie on paper
    Step5)Take your rough paper trace template and put it over the ceiling light lense and trace w/sharpie and cut it out w/the dremel.
    Step6) Test fit it on the backing to make sure it will fit and make the necessary trimming to make it fit(notice how it hangs too much on it at first.. that needs to be trimmed)
    Step7)Test fit it on the actual clear lens of the tail and make sure it will slide in there. This material does break and crack. Dont worry, this first cut out will get broken, just tape it up and keep test fitting and trimming until it slides in and out perfect. after you get the perfect fit, take out your rough one and make a new lense using your trimmed and perfected one
    Step8) Now after youve done that big mess, take the backing you have cut and trim and clean up all the edges that you cut and lightly sand the inside(if your going to paint) and prep it for paint.
    Step9) Now take your newly painted and dried backings and take your washer and silicone and add a bead of silicone on the bulb hole and press the washer on and let dry
    Step9)Now depending if you go w/LED trailer lights or bulbs you will or wont have to do this. if you go w/the LED trailer lights, first position the light so that the bold lies flat, mark it then the wires need to come out somewhere, and not through the bulb hole. So take your drill and drill a hole big enough for all three wires to go thru
    Step10)I dont have pix of this step, but after youve marked the back of the Led with sharpie where the flat part of the bolt is gonna go, scuff it up and JB weld the bolt to the back of the LED. After this dries go ahead and put the LED into place and put the Nut on there and silicone any gaps
    Step11) Almost done! after this step is done, just prep the backing and clear lens and JB Weld it and then follow it up with a bead of silicone. Connect your wires and test them and your done!
    Now w/LEDs you will need a Resistor which i still havent gotten but all i have is hyperflash for now on mine.
    *if you have any questions about a step or anything Let me know. This is my first write up so i might have missed something. Hope you like and Enjoy. i know i do!
    PS ill have night pix posted possibly tommorow
    http://a3.sphotos.ak.fbcdn.net/hphotos-ak-ash4/298768_845262999451_44010243_38019424_857341283_n.  jpg
  2. #2 Re: Squeeze's How to "clear lensed GP tails"
    very nice,
    i like how the first tool listed is a hammer
    SMGPFC Member #10
  3. #3 Re: Squeeze's How to "clear lensed GP tails"
    GT Level Member Tommyp2010's Avatar
    Poland, Ohio
    I'm not sure if I would call these "clear lenses" as much as frosted lenses. Not a huge fan personally, but this isn't my car either. A for effort and creativity
    2006 Mitsubishi Evo IX MR
  4. #4 Re: Squeeze's How to "clear lensed GP tails"
    I live here. TLSheff's Avatar
    Love it, Great job!!!
  5. #5 Re: Squeeze's How to "clear lensed GP tails"
    Norman, OK
    Quote Originally Posted by Tommyp2010 View Post
    ya id agree they do look more frosted than clear.
    ya i still havent taken a night shot yet either! lol and ya these lights arent for everyone just another option as far as appearence goes for our cars
  6. #6 Re: Squeeze's How to "clear lensed GP tails"
    GTX Level Member bandits grand prix's Avatar
    Jul 2010
    connecticut
    imo it looks like they got really water logged :/ black them out
  7. #7 Re: Squeeze's How to "clear lensed GP tails"
    Jun 2011
    Detroit, MI
    Not quite bright enough for me. But they look nice.
    iLoveSpade
  8. #8 Re: Squeeze's How to "clear lensed GP tails"
    Windsor (ON) Canada
    I like the added "GT" on the right lense.
  9. #9 Re: Squeeze's How to "clear lensed GP tails"
    Jul 2008
    Tampa, FL
    interesting. i like...
  10. #10 Re: Squeeze's How to "clear lensed GP tails"
    Sep 2011
    seattle
    definitely give u a da** A as to taking stock light housing apart, for the reason most people fail. i have something for u guys too look at if any of u guys have time google oracle halo lights they manufacture halo rings that r all led surrounding the entire circle now that would be cool inside these lights but just a idea. i think i may do the same thing but find a ring that will fit inside my tail lights an use a led bulb replacement they r just as bright. but it looks pretty darn good to me good job squeeze
  11. #11 Re: Squeeze's How to "clear lensed GP tails"
    Norman, OK
    Quote Originally Posted by goshay21c View Post
    That sounds like a cool idea too, if you do it definitly gotta post pix. I might be doing another set like this soon for another Gp bud of mine.
  12. #12 Re: Squeeze's How to "clear lensed GP tails"
    Donating Users RareGMFan's Avatar
    Dec 2008
    Naperville, IL
    Quote Originally Posted by squeeze View Post
    ...wait, I don't get it. Is step 2) take your pants off, and THEN use the dremel??
    PREVIOUS: '89 Pontiac 6000 STE AWD (2/1376), '90 Pontiac GP SE McLaren Turbo (1/2749)
    '90 Pontiac Grand Prix STE McLaren Turbo (1/1000), '01 Pontiac GP GTP Special Edition (1/1341)
    CURRENT: '00 Pontiac Grand Prix GTP (ugh...boring regular one)
  13. #13 Re: Squeeze's How to "clear lensed GP tails"
    Norman, OK
    Quote Originally Posted by RareGMFan View Post
    EXACTLY! haha gotta get in the mood! Haha na Jp I was fully clothed, just forgot to hang up a pair of pants, knew someone would say something sooner or later haha
  14. #14 Re: Squeeze's How to "clear lensed GP tails"
    Donating Users crock's Avatar
    Traverse City, Michigan
    Where do you get the LED mabob at? Im intrested in trying this out. The Finished product is sweet.
    99 GTP- 104s, 180 Tstat, 1.9 rockers, 3.4, ls1 MAF, KN, 3''DP, HF cat, GMPP Strut Bars, Crappy Tune, Broken Tensioner Mod.
  15. #15 Re: Squeeze's How to "clear lensed GP tails"
    Norman, OK
    Quote Originally Posted by crock View Post
    I got Mine off eBay, they are a 32 LED semi tail light. They ran me about $35 or so. I know there is another site that sells a 15 LED light I believe but I'd have to find the link for it again.
  16. #16 Re: Squeeze's How to "clear lensed GP tails"
    michigan
    I think they're badass bud. Wish I had the patience for something like that. Id prob get to step two then use the hammer!! Lol
  17. #17 Re: Squeeze's How to "clear lensed GP tails"
    Norman, OK
    Quote Originally Posted by twol8uluz View Post
    haha hammer time!
  18. #18 Re: Squeeze's How to "clear lensed GP tails"
    SE Level Member Curt7's Avatar
    Jul 2011
    Ontario
    Nice right up! I likee that sh*t
    2003 Grand Prix GT
  19. #19 Re: Squeeze's How to "clear lensed GP tails"
    Jul 2011
    new oxford, pa
    awesome tails man they look sick!! id love to have a set on mine like that, but i just dont have the time to put into making em, only thing id have different is leaving the lightbulbs alone bc i know l.e.d's arent always reliable , other than that they look great
  20. #20 Re: Squeeze's How to "clear lensed GP tails"
    Norman, OK
    Quote Originally Posted by Fastredgtp View Post
    Ya I popped a red bulb in there and snapped a pic and it was decent output
  1. Possible new way of "clear" tails?
    By squeeze in forum General Tech Discussion
    Last Post: 10-22-2011, 12:42 AM
  2. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  3. The Explosm Store - "Squeeze" T-Shirt
    By TLSheff in forum Off Topic Discussion
    Last Post: 06-23-2011, 06:47 PM
  4. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
