Thread: 04+ 3 button to 5 button upgrade
Results 1 to 20 of 28
  1. #1 04+ 3 button to 5 button upgrade
    London Ont, Canada
    How to update from a 3 button to a 5 button DIC 2004+ Grand Prix
    1. Get yourself a 5 button DIC and bezel (cutting out holes just isn’t classy enough)
    2. Go to a junkyard and cut out the DIC connector with some wire attached
    3. Cut out the DIC connector from your current car (don’t cut it too far into the car you want to leave space to work)
    4. Connect the 2 DIC connectors into 1 Y piece (solder and heat shrink tubing are best obviously)
    I didn’t get a pic of this being done, but it’s pretty basic. Just match the connectors, make them nice ,you literally want a Y 2 plus one side, and a pigtail out the back.
    5. Next comes the “fun” part, cutting out part of your dash. When you take the DIC bezel off you will see the round air vent on the right and a square plastic piece on the left. You need to cut out some of that square plastic piece so that you have room to slip the DIC behind it. (you could really run the DIC to anywhere you want, but the dash is easy)
    6. Next take the 3 button DIC and take it apart CAREFULLY! You are going to need to keep the 3 button housing for a later date and don’t wanna break it. Unhook the main screen, this is the part we want.
    7. We need something to store this unit in, can’t have it bouncing around shorting out or causing issues. So let’s get a box!
    I got this tin at Micheals crafts shop, who knows if that’s available in America! Just get a small box that will hold the unit.
    8. Since the box I used was metal I had to insulate it somehow, so I used craft foam, self adhesive and thick ones too
    9. You’re going to want to essentially line the box with the stuff, also make some pieces that will go on top to help stuff the box so the DIC screen doesn’t rattle around
    10. Cut a hole in the box to allow the connector to slide in.
    11. Also take a moment to add some ventilation holes
    12. Stick the screen in the box
    13. Next comes another “fun” part, we need to do some soldering in the car! I really don’t ever recommend crimp connectors, or just twist and tape... do it right people!
    We are going to solder the pigtail end of the Y into the main harness of the DIC, simple stuff, just match the colours like you did when making the Y
    14. Now that you have the Y connector soldered into the harness you can plug in the 3 button in the box, make sure that you plug it in properly, the tines on the DIC should go in the middle of the connector (has 4 rows of holes for the tines) have a few spare 10amp mini fuses on hand, I had a panic when I blew a fuse and didn’t realize, thought I broke everything, I had just plugged it in wrong!
    15. Once it plugged in, you can see on the screen if it works or not, then stuff that baby behind the dash in the hole you cut out earlier
    16. Hook up the 5 button unit
    17. Enjoy your 5 button success!!! And you only spent a few more bucks then buying the DIC. Way better than paying to have a tech reprogram it, or buying all those parts online as the other DIY method says.
    When I did this on mine to help make the transition easier I left the 3 button plugged in until I had reached a easy to remember spot. So my 3 button had 192226km and the 5 button had 77510km, so I ran up the 3 button until it reached 192510km, then plugged in the 5 button, they are now both picking up the KM’s and I’m only off by exactly 115000km.
    The reason you are keeping the 3 button housing is so that if you ever need to you can take it outta the box then reassemble the unit, and use it as you need to. Just remember soon as you unplug it it will change the screen it’s on! But if you ever need to show your exact mileage or anything you can just reassemble the 3 button, and put it in the 5 button bezel (you will have 2 extra holes) but who cares! Or you can keep the 3 button trim too, and just swap whenever you need to. Choice is yours.
    This is just a guideline, not exact details. I have no liability for this working or not, or your car exploding into a firey mess. If you have any questions about this or want help, just PM me and I will see what I can do!
  2. #2 Re: 04+ 3 button to 5 button upgrade
    GTP Level Member Javi's Avatar
    OKC, Oklahoma
    Wow thats a good idea.
    You welcome..
    Note: if you tap the original wiring and use it to run the new 5 button DIC It will show OC on the bottom right hand corner where the temperature its usually display.
  3. #3 Re: 04+ 3 button to 5 button upgrade
    London Ont, Canada
    Quote Originally Posted by Javi View Post
    You welcome.
    Thanks for the info! sure helped.. figure i'd share!
  4. #4 Re: 04+ 3 button to 5 button upgrade
    Kansas
    You welcome..
    It shows OC because you don't have a AAT sensor plugged into the harness. Also the compass will show CAL.
  5. #5 Re: 04+ 3 button to 5 button upgrade
    Jun 2011
    Nice write up! Lol could you imagine someone drilling the 2 holes.
  6. #6 Re: 04+ 3 button to 5 button upgrade
    London Ont, Canada
    The DIY method has you drilling 2 holes...
  7. #7 Re: 04+ 3 button to 5 button upgrade
    Chilliwack BC
    gdam it. if i buy another 5 button bezel i gotta get it painted again. (love my red bezel)
    edit: nice writeup monkey!
  8. #8 Re: 04+ 3 button to 5 button upgrade
    GT Level Member tylerbinski's Avatar
    Canada
    Thanks for the write up. Just one part I am unclear on. What is this warning mean?
    Thanks for clarifying
    '04 BLK GP - .. Turbo :P
    GTP SIC - '02GTP | XP Cam | Intercooled Turbo Kit | Cutout....Fire mod 9/11
    GTPSIC '02 | Twin charge, XP cam et
  9. #9 Re: 04+ 3 button to 5 button upgrade
    London Ont, Canada
    What I mean by that is if you set it up to show the milage screen then stash it you can open it up later and see the milage. But if you unplug it it will show something else and you would need the. Buttons to change it back.
    Really it's a personal thing doesn't impact anything lol just my anal retentiveness coming out
    To be honest I haven't looked at mine in ages. I checked it out like a week after and it was doing good. Now I kinda wanna go look see if it's ok lol
  10. #10 Re: 04+ 3 button to 5 button upgrade
    Canada
    Thanks for clarification, good point. I get it now and will also leave mine on mileage back there
    cheers
  11. #11 Re: 04+ 3 button to 5 button upgrade
    Kansas
    Or just be a bauce and plug in the 5 button and be done with it.
    Nice writeup though Jordo
  12. #12 Re: 04+ 3 button to 5 button upgrade
    Canada
    lol, I found a 5button with 49,000 miles on it for $100 with bezel shipped, going to do a parallel setup I think.
  13. #13 Re: 04+ 3 button to 5 button upgrade
    London Ont, Canada
    mine just shows Cal now.. got temp like a champ.
  14. #14 Re: 04+ 3 button to 5 button upgrade
    Canada
    Do you mean OAT (outside air temp?) that lil temp sensor guy in the front bumper area right?
    Just a matter of plugging one in? (I think i have one from my 2002 still somewhere)
    and as far as compass goes.. where do i plug that in? or is that part of the onstar **** in the trunk that was ripped out?
  15. #15 Re: 04+ 3 button to 5 button upgrade
    Omaha, NE
    Quote Originally Posted by tylerbinski View Post
    GM called it an Ambient Air Temp sensor. My 04 already had one, but they are $5 or less new from a dealer.
    The compass module sits in the rear speaker shelf just to the drivers side of center.
  16. #16 Re: 04+ 3 button to 5 button upgrade
    Canada
    Ah AAT it is then
    Thanks, and for the compass module, is that a straightforward install also, plugs into existing clip?
    idea on price?
  17. #17 Re: 04+ 3 button to 5 button upgrade
    Omaha, NE
    Last I checked compas modules new were over $150 and around $100 used. They have dropped slightly since.
    I already had the wiring harness for it in mine, I have heard a few don't. You may want to check before buying one.
  18. #18 Re: 04+ 3 button to 5 button upgrade
    London Ont, Canada
    Yea, what he said.. I havnt looked to see if i have an adapter or not. dont have the module yet to even worry about it.
  19. #19 Re: 04+ 3 button to 5 button upgrade
    Dec 2011
    Nerbraska
    so i know this is an old thread but i up graded my 04 from a 3 to a 5. added the temp sensor and the compass module. everything works but it wont hold the date.. any ideas?
  20. #20 Re: 04+ 3 button to 5 button upgrade
    London Ont, Canada
    Do you have an aftermarket stereo? Because that nukes date on ddice here was your plug for the compass?
  1. How-to: 5 button DIC upgrade (no reprogram necessary) (04+) [*]
    By TyroElite in forum How To Write-Ups/Tech Tips
    Last Post: 06-05-2012, 11:59 PM
