Thread: 04+ 3 button to 5 button upgrade
Results 1 to 20 of 28
  1. #1 Re: 04+ 3 button to 5 button upgrade
    GTP Level Member Javi's Avatar
    OKC, Oklahoma
    Wow thats a good idea.
    You welcome..
    Note: if you tap the original wiring and use it to run the new 5 button DIC It will show OC on the bottom right hand corner where the temperature its usually display.
  2. #2 Re: 04+ 3 button to 5 button upgrade
    London Ont, Canada
    Quote Originally Posted by Javi View Post
    You welcome.
    Thanks for the info! sure helped.. figure i'd share!
  3. #3 Re: 04+ 3 button to 5 button upgrade
    Kansas
    You welcome..
    It shows OC because you don't have a AAT sensor plugged into the harness. Also the compass will show CAL.
  1. How-to: 5 button DIC upgrade (no reprogram necessary) (04+) [*]
    By TyroElite in forum How To Write-Ups/Tech Tips
    Last Post: 06-05-2012, 11:59 PM
