Thread: dic swap?
Results 1 to 20 of 31
  1. #1 dic swap?
    Feb 2010
    TN
    Can you swap the basic DIC on a 97 grand Prix gt for the one that gives gas mileage etc? that's on the 98? If yes how easy is it to do?
    Thanks
  2. #2 Re: dic swap?
    PA
    No, I don't believe so. It's not that easy.
    2001 GSE
  3. #3 Re: dic swap?
    Kansas
    Not as easy as 04+
  4. #4 Re: dic swap?
    Omaha, NE
    Sounds like your car is stuck with the dic it was born with.
  5. #5 Re: dic swap?
    GTX Level Member Juanmiguel's Avatar
    Mexico
    Sounds like youre stuck with the dic k you were born with.
    Fixed
  6. #6 Re: dic swap?
    Yoga city
    Yes you can get 97 gtp dic and go from there. 97 will only work on 97
  7. #7 Re: dic swap?
    Since no one else helped...... Please read here....http://www.grandprixforums.net/addin...3-gp-8171.html I've done this personally on my 97. Its worked great with no flaws. Just make sure you get the DIC from a 97 GP only.
    Snorlax strikes again.
  8. #8 Re: dic swap?
    Feb 2010
    TN
    Ramairgt2 Thanks a ton I really appreciate this, I'll make sure I tell Santa how good you were.
  9. #9 Re: dic swap?
    Feb 2010
    TN
    Quick question since I already have a hud I am guessing not as much splicing correct?
  10. #10 Re: dic swap?
    Feb 2010
    TN
    ops one more question if I have a choice between digital and analog is one easier to swap with what I have now?
  11. #11 Re: dic swap?
    ok so you do have a HUD display on your car that shows your speed etc on your windshield???? If you do , you should already have the DDIC (digital driver info center) but it seems the one you have is the analog which doesn't show anything except warning lights. Is this right?
  12. #12 Re: dic swap?
    Feb 2010
    TN
    That's correct shows when a door is open the the light for tire pressure and trac and oil change
  13. #13 Re: dic swap?
    Donating Users str3etgl0w's Avatar
    Jun 2011
    Saginaw Mi
    my 97 had the plug for the digital dic already there its burryed back in the dash but u can put a 97 dic out of a gtp and put it in a 97 gt took me 20 secs
  14. #14 Re: dic swap?
    Ok make sure you get a 97 only DIC. You'll need it because of the check tire pressure light... It should look like mine.
    This is the old analog one when I first got the car....
  15. #15 Re: dic swap?
    My 97 didn't have the HUD on the windshield so there wasn't a plug for me to just plug my dic into. I had to wire it up because my car started its life out as a SE ..... its now a GT. Since your 97 is a GT it may already have the plug inside the dash wrapped up with the other wire harness ,but just in case it doesn't make sure when you purchase the 97 DIC you get it with the harness/pig tail.... I now own a fully loaded 01 GTP so I didn't have to worry about adding stuff to it :P
  16. #16 Re: dic swap?
    Feb 2010
    TN
    Thanks so much I really appreciate this especially the pics of what to get I sent a few of these in the junk yards by me and my next trip out there I plan on grabbing one. I got hit by a deer so this started a slow but steady rebuild and some add ons. I just needed a hood and fender, but decided to get the gtx hood and from there is just snowballed redoing everything you know how it goes I am sure
  17. #17 Re: dic swap?
    The Boss Iceman6669's Avatar
    Jun 2011
    Ramairgt2 did some of the 97 DIC come with the Trac push button? cause My GTP looks just like the one in the pic but no trac off button.
  18. #18 Re: dic swap?
    As far as I know they all had the trac button, in later GP's they had the TCS button. they both do the same thing as disabling the trac control.
    I just found this one with out the trac button on ebay...http://cgi.ebay.com/ebaymotors/97-Po...item3f0ba9f51b , I've actually never seen a GP with this style DIC in it.....
  19. #19 Re: dic swap?
    Jun 2011
    Saginaw Mi
    my 97 GTP does not have the trac button I though that was in 98+
  20. #20 Re: dic swap?
    nope. My 97 came with it even before I swapped the dics out.... I think it might have been an option to have it removed or on all the time????? at the time the 97 GP's came out
  1. '95 3.1L to '00 3.8L swap.
    By TvMarine in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-19-2013, 01:14 AM
  2. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  3. L26/l36 swap help
    By GOINDEF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-11-2010, 02:09 PM
