Thread: L26/l36 swap help
Results 1 to 8 of 8
  1. #1 L26/l36 swap help
    GT Level Member GOINDEF's Avatar
    Holly, MI
    I was just wondering if someone can give me detail instructions or pictures as to what I have to extend for vaccum lines and anything else with putting an L26 INTO A 98 GT with an L36.
    thanks for any kind of help
  2. #2 Re: L26/l36 swap help
    Holly, MI
    gee thanks everyone, it's hard to believe that NO ONE has EVER done this swap, and that they dont want to help AT ALL
  3. #3 Re: L26/l36 swap help
    use all your stock vacuum lines...why would you change them?
  4. #4 Re: L26/l36 swap help
    Probably keeping the metal upper, which might require slight extending, but that's simple vacuum hose.
    Do you have any more specific questions? Seems like you didn't post just about the vacuum lines, but with the blocks, heads etc all being nearly identical from an install point it's tough to guess what you'd like help with.
  5. #5 Re: L26/l36 swap help
    but i had the l26 upper on my car and i never changed any of the vacuum lines..
  6. #6 Re: L26/l36 swap help
    Holly, MI
    well I was told that I had to extend vacuum lines and stuff, but I don't know what ones where to and how do I extend them, plus is there anything else I have to do.
    I'm getting the adapter plate and a throttle body for it, I know that I have to use my l36 fuel lines, is there nething else
  7. #7 Re: L26/l36 swap help
    Ok, that gives us a much better understanding of what you are asking.
    From the outside an L26 is the same as an L36 except for the metal upper manifold and the drive by wire.
    With that in mind, you'd use the adapter plate and your evap line to the port on the TB may need to be extended slightly. Other than that, you should be able to plug and play the rest. It's a straight forward swap once you put the engines side by side and ensure the evap set and rear manifold is swapped over.
  8. #8 Re: L26/l36 swap help
    Holly, MI
    ok so then all I have to do is extend just the vacuum lines from where they are now back to the throttle body after the engine is installed thats it?
  1. gt gtp swap
    By danross in forum General Tech Discussion
    Last Post: 05-28-2013, 11:56 AM
  2. Top Swap
    By MetalMan in forum General Tech Discussion
    Last Post: 04-30-2010, 07:51 AM
  3. L32 swap
    By DaytonaGTP in forum General Tech Discussion
    Last Post: 04-24-2010, 11:16 AM
  4. Top Swap Help
    By kfish in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-11-2009, 04:53 PM
  5. gto swap
    By CHAMPS97 in forum General Tech Discussion
    Last Post: 09-02-2009, 05:32 AM
