Thread: boost bypass valve instructions
Results 1 to 10 of 10
  1. #1 boost bypass valve instructions
    SE Level Member mosinnagant's Avatar
    May 2011
    edgewood
    i found this on a SVT cobra forum but it should work on our supercharged since it would be the same basic principal. it also come's with pictures!
    "BOOST BYPASS" Installation Instructions for the 2003, 2004 Supercharged Mustang SVT Cobra
    2007 Grand Prix GT - Green Filter Cone Intake, 180 F Thermostat, EGR Delete, Overkill Custom Tune, Muffler Delete with Thrush Glasspack res swap, Kenwood head unit
  2. #2 Re: boost bypass valve instructions
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    im scared this will make me go boom
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  3. #3 Re: boost bypass valve instructions
    The Boss Iceman6669's Avatar
    Jun 2011
    Funny you post this... I just talked to blue the other day about the idea of doing something like this and he said it would have NO benefits. He said all it would do is RUIN your MPG's
  4. #4 Re: boost bypass valve instructions
    its used for TCS.
    When it engages it tries to pull boost because it also randomly cuts fuel and spark.
    So lots of air, not much fuel, tcs, boom.
    I've never run one. Trac off permanently.
    Won't affect fuel economy in the slightest.
    Forcing the valve shut all the time would affect fuel economy though.
  5. #5 Re: boost bypass valve instructions
    New Carrollton,MD
    our bost actuator doesn't have boots i don't think the line switch would work
  6. #6 Re: boost bypass valve instructions
    Buffalo
    Top swaps don't run it. I don't run one. I also have a hpt so it was easier to just delete the code "turbo wasgste solenoid" Much better.
    Plus you see how 1/4 times are longer than 10sec? Well look at your boost timer....Might want to disable the timer too so the PCM doesnt interfere and cut boost. When I checked a tune recently it was set for 10 seconds
    Best bet it to just disable the solenoid and leave one vacuum line on the bbv
  7. #7 Re: boost bypass valve instructions
    You would simply remove the solenoid, chuck it, and the lines on it.
    The BBV actuator would now have the bottom nipple open to atmosphere and the FPR line i believe would now need to end at the FPR instead of continuing to the BBV solenoid.
    Again, traction control will be inoperable without this device functioning properly.
  8. #8 Re: boost bypass valve instructions
    New Carrollton,MD
    Yea traction control never works anyway because the wheel bearing lines always snap LOL. I did the method ZZP showed and mine definitely moved a good distance and it feels like my boost kicks in a lot fast when i stomp it than it did before. Drop in fuel economy is equal to when you drop thermostat temperatures.
  9. #9 Re: boost bypass valve instructions
    Wheel bearing lines?
  10. #10 Re: boost bypass valve instructions
    New Carrollton,MD
    ABS line/ cord
  1. Need help!~ with bypass valve boost actuator
    By dreama in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2012, 09:22 AM
  2. Boost Bypass Valve is it the same as a BOV?
    By xsvtank in forum General Tech Discussion
    Last Post: 08-06-2010, 12:12 PM
  3. Boost Bypass Valve help
    By mikeh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2009, 01:20 AM
  4. Boost Bypass Valve Questions....
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2008, 08:25 AM
