WATCH THE VIDEO
‪Ported Gen 3 M90 supercharger‬‏ - YouTube
Just ported out my gen 3 blower because I can't really afford to go for a gen V. Here is a video that can help you compete with the gen V if you have a larger throttle body setup.
After you remove the blower, you will need a Dremel or any type of rotary tool, a squeeze spray cap with the straw attached, a dust mask, 10mm socket and ratchet with an extension , a pair of goggles, some supercharger oil, A metal boring bit, and some grinding stones.
This one here...^ is the one I used
Use your squeeze spray cap to spray out your supercharger oil. and remove the bolts on the snout with a 10mm socket ans a small extension to take off the snout and take out the rotor packs. The oil fill is removed with a size 5 allen wrench
Good Luck and enjoy the extra power!!
