Thread: p0420 Catalyst System Efficiency Below Threshold (Bank 1)
Results 1 to 3 of 3
NaturallySmashed p0420 Catalyst System... 08-12-2009, 12:41 PM
BillBoost37 Re: p0420 Catalyst System... 08-12-2009, 12:45 PM
NaturallySmashed Re: p0420 Catalyst System... 08-12-2009, 01:05 PM
  1. #1 p0420 Catalyst System Efficiency Below Threshold (Bank 1)
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    Just figured I'd make a post to see what you guys think.. I believe this code is usually for a bad catalytic converter.. I have no way to test it. Should I just change the o2 sensor first? Also, would that be the o2 after the cat?
  2. #2 Re: p0420 Catalyst System Efficiency Below Threshold (Bank 1)
    The code tells you that the difference in readings before and after the cat do not have the necessary amount of change as expected by the pcm with a good functioning cat.
    The sensors are seemingly reading ok. There shouldn't be a need to change a sensor.
  3. #3 Re: p0420 Catalyst System Efficiency Below Threshold (Bank 1)
    Medford, NY
    Thought so.. ugh. Thanks
  1. P0420 code
    By BChimo in forum General Tech Discussion
    Last Post: 10-18-2012, 12:18 PM
  2. P0420 Code keeps setting on 2001 GTP
    By Littlegiant in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2008, 07:50 PM
  3. Tranny mods for efficiency? (MPG)
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-22-2008, 09:27 AM
  4. Tuning for fuel efficiency...
    By Sabrewings in forum PCM Tuning
    Last Post: 05-31-2008, 11:59 PM
  5. p0420 code on
    By fst in forum General Tech Discussion
    Last Post: 01-05-2008, 04:19 PM
