Thread: Porting Your Gen 3 for better efficiency
Results 1 to 9 of 9
OrangeL67 Porting Your Gen 3 for better... 07-14-2011, 05:50 PM
Wotgtp Re: Porting Your Gen 3 for... 07-14-2011, 06:04 PM
JoRoW99 Re: Porting Your Gen 3 for... 07-14-2011, 07:56 PM
OrangeL67 Re: Porting Your Gen 3 for... 07-14-2011, 08:16 PM
dsmuts Re: Porting Your Gen 3 for... 07-14-2011, 08:12 PM
JoRoW99 Re: Porting Your Gen 3 for... 07-14-2011, 08:35 PM
OrangeL67 Re: Porting Your Gen 3 for... 07-14-2011, 08:50 PM
JoRoW99 Re: Porting Your Gen 3 for... 07-14-2011, 08:59 PM
matt5112 Re: Porting Your Gen 3 for... 07-15-2011, 12:22 AM
  1. #1 Porting Your Gen 3 for better efficiency
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    WATCH THE VIDEO
    ‪Ported Gen 3 M90 supercharger‬‏ - YouTube
    Just ported out my gen 3 blower because I can't really afford to go for a gen V. Here is a video that can help you compete with the gen V if you have a larger throttle body setup.
    After you remove the blower, you will need a Dremel or any type of rotary tool, a squeeze spray cap with the straw attached, a dust mask, 10mm socket and ratchet with an extension , a pair of goggles, some supercharger oil, A metal boring bit, and some grinding stones.
    This one here...^ is the one I used
    Use your squeeze spray cap to spray out your supercharger oil. and remove the bolts on the snout with a 10mm socket ans a small extension to take off the snout and take out the rotor packs. The oil fill is removed with a size 5 allen wrench
    Good Luck and enjoy the extra power!!
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
  2. #2 Re: Porting Your Gen 3 for better efficiency
    Mullet Member Wotgtp's Avatar
    Connecticut
    Nice write up.
  3. #3 Re: Porting Your Gen 3 for better efficiency
    Grand Island, Nebraska
    Cool video. Also make sure you get some washers or shorter bolts and thread sealant since you basically open the threads to boost when you port it like that. I would also open up the bottom like ZZP has.
    How do you like the LS1 TB?
  4. #4 Re: Porting Your Gen 3 for better efficiency
    Nov 2009
    Michigan
    Quote Originally Posted by JoRoW99 View Post
    I thought about removing the H bar, but there's no gain in it for me with the type of intercooler I'm running. It would be perfect with a ZZP core tho. I love the LS1 TB. It's a kick every time I hit the throttle.
  5. #5 Re: Porting Your Gen 3 for better efficiency
    I'm doing this right now to mine too. Then on goes the 3.4
  6. #6 Re: Porting Your Gen 3 for better efficiency
    I didnt mean the H bar. I mean toward the left of that picture, so like the bottom of the triangle. The rotors go all the way back so if you open that up almost to the wall, the rotors wont be pushing air against that lip as much.
  7. #7 Re: Porting Your Gen 3 for better efficiency
    Nov 2009
    Michigan
    Oh I see what you mean. Good call! I'll probably do mine the same way before I get it bolted back on. Thanks
  8. #8 Re: Porting Your Gen 3 for better efficiency
    Yea no problem. zzp has a supercharger dyno so I figured they would know.
  9. #9 Re: Porting Your Gen 3 for better efficiency
    this thread already exists.
    zomg.
    all you do is remove the bolt hole type things, nice bevel and call it a day.
    Do appreciate the video though.
    You don't need a gen V LIM, just cut a larger hole in the LIM to match the outlet of the gen V. Never understood why people bothered with that bit.
  1. TB porting
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-15-2011, 07:39 AM
  2. Porting Gen 5 M90
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2010, 02:38 AM
  3. p0420 Catalyst System Efficiency Below Threshold (Bank 1)
    By NaturallySmashed in forum General Tech Discussion
    Last Post: 08-12-2009, 01:05 PM
  4. Tranny mods for efficiency? (MPG)
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-22-2008, 09:27 AM
  5. Tuning for fuel efficiency...
    By Sabrewings in forum PCM Tuning
    Last Post: 05-31-2008, 11:59 PM
