Thread: How to Mod a LIM
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 61 to 80 of 105
  1. #61 Re: How to Mod a LIM
    Apr 2011
    Vassar, Mi
    How about drilling and tapping the front PCV passage for IC plates where front PCV is blocked off? LIM improvement and so much nicer than having a hose barb sticking out of the oil fill cap.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  2. #62 Re: How to Mod a LIM
    Mercer, Pa
    Didn't think the fitting in my oil cap extension was so bad.
  3. #63 Re: How to Mod a LIM
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    Quote Originally Posted by sseilmnop View Post
    In that rats nest you can hardly tell lol. I do like your intercooler hose routing though!
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  4. #64 Re: How to Mod a LIM
    Mercer, Pa
    Not the prettiest but should be turning 200,000 miles this month. Runs everyday rain or snow.
  5. #65 Re: How to Mod a LIM
    Apr 2011
    Vassar, Mi
    Yea I didn't want my PCV sticking out like a sore thumb. I don't have hardly anything on the front of my engine.
  6. #66 Re: How to Mod a LIM
    I'll add when this damn pc works right.
  7. #67 Re: How to Mod a LIM
    Bettendorf, IA
    So is the L27 LIM different? Not have same issues?
  8. #68 Re: How to Mod a LIM
    The L27 is a Series 1 engine produced from 91-94 and does not swap onto the Series 2.
  9. #69 Re: How to Mod a LIM
    Bettendorf, IA
    My bad, L26. 2004
  10. #70 Re: How to Mod a LIM
    Bettendorf, IA
    Quote Originally Posted by Anthony Smith View Post
    That Is clean looking engine.
  11. #71 Re: How to Mod a LIM
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    ^Agreed!
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  12. #72 Re: How to Mod a LIM
    Jan 2014
    New Knoxville Oh
    R the radiators for the GTP and gt gp interchangeable
  13. #73 Re: How to Mod a LIM
    Apr 2014
    CT
    I want to thank you for this thread! I had to do my LIM gaskets and saw this. I was able to locate end plugs. One thing I might of done different is I would of ground down the plug so I wouldn't have to tap so far to get it flush. The aluminum is thin there and its a fine line of getting the tap in just right! I believe I went about 13 1/2 turns on the first one so the second one I turned the tap in 12 turns and then slowly creeped it until I got the plug flush.
  14. #74 Re: How to Mod a LIM
    GT Level Member Flip97GTP's Avatar
    May 2013
    Ft. Lauderdale, Florida
    What performance advantages will you get, when this is done?
    My 1997 Grand Prix GTP progress build thread!
    Mods At The Moment: 160+ Amps Alternator.
    Mods I Will Be Doing In 2015: Speed Daddy Headers, 3.4" Modular Pulley System, Open Air Intake, BillBoost Tune, TransGo SK® 4T65E Transmission Shift Kit, 180* Thermostat
  15. #75 Re: How to Mod a LIM
    Did u bother to even read the first post it answers everything for you
    04 Comp G.
  16. #76 Re: How to Mod a LIM
    May 2013
    I'm sorry your highness
  17. #77 Re: How to Mod a LIM
    May 2013
    Yes I did and this wasn't in the first post "The ported supercharger housing increases the mass of air flowing out of the supercharger outlet by enlarging the factory restricted outlet and reduces heat generation resulting in an increase in horsepower."
    This is the answer I was, more or less, looking for. Thanks anyway! I did a little research and found this. With that being said, I will do a lot more research before asking any questions.
  18. #78 Re: How to Mod a LIM
    Kemmerer, Wyoming
    Aeroforce sells an air temperature sensor kit, but it is probably over priced. any idea if the aforementioned Camaro sensor will send the right signal to the aeroforce gauge? or should I just get the Camaro sensor and another gauge, either way it will end up costing about the same.
    http://aeroforcetech.com/products_sensors_temp.html
  19. #79 Re: How to Mod a LIM
    I plugged into it..and it read temp perfectly.
  20. #80 Re: How to Mod a LIM
    Kemmerer, Wyoming
    Did you plug the temp sensor into an aeroforce, and it worked?
lim, mod
