Thread: How to get PCV to work instead of valve cover breather!
Results 1 to 20 of 122
  1. #1 How to get PCV to work instead of valve cover breather!
    Mercer, Pa
    There at 2 holes hear as well. One is hard to see, but it is smaller and shinny.
  2. #2 Re: How to get PCV to work instead of valve cover breather!
    Feb 2013
    Detroit, MI
    Quote Originally Posted by sseilmnop View Post
    Okay I see them, now should I drill and tap where that picture is, (front left) or do I need to have it near the 'a' & 'n' holes?
  3. #3 Re: How to get PCV to work instead of valve cover breather!
    Mercer, Pa
    Quote Originally Posted by GrandPrix06GT View Post
    The hole in the rear is a separate issue from the fitting in front.
    The rear hole sucks (vacuum) air out of crankcase. You need to let air in so on the front you drill and tap a hole in valve cover/cap/ or in sideways into LIM. This lets the air into the crankcase. This hole in front connects with a hose to throttle body.
  1. Valve Cover
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2011, 10:24 AM
  2. Valve cover Breather
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2011, 06:27 PM
  3. Valve Breather Modification And Repair [*]
    By nemesis in forum How To Write-Ups/Tech Tips
    Last Post: 12-21-2008, 07:47 PM
  4. Valve Cover
    By justaV6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 09:15 PM
