Ok but the rear keep it hooked up to my tb as I had prior to installing the ic correct?
Also that picture you mentioned is the only one not showing.
Thanks for the quick reply by the way.
So should I just tap into the neck up front and route it to the same connection on the tb as the rear one correct?
That way I have both front and rear working.
