Thread: hv3 install
Results 1 to 20 of 28
  1. #1 hv3 install
    Jul 2008
    Tampa, FL
    this is a writeup on how i did my hv3 install on my 2007 base GP.
    tools needed:
    any tools that you might need to remove your air intake. i only needed a flathead screwdriver.
    Socket set. i used my 1/4 drive socket with a long extension so you can maneuver around the height of the UIM. (you will mostly be dealing with 10mm, and 8mm, i recommend using the 6pt sockets so you do not strip the bolts.)
    i used a dremel tool to cut off some clips on the UIM gasket that held a pcv pipe.
    make sure to begin this when your car is completely cooled down, i waited about two hours after i had gotten home from work, and i finished the job in about an hour and a half.
    i began by removing my air intake setup.
    i then removed spark plug wires #2/#4/#6 from the coil pack assembly and tucked them behind the engine.
    the next thing i did was disconnect all connectors that i thought would prevent me from lifting up the UIM. i believe there were 4-5 connectors and i'm not exactly sure what they are or do.
    next step is to release the pressure from the fuel rail. unscrew the black cap and there is a valve like on a tire. lightly push the valve with your finger or a small flathead. some fuel may shoot out, but mine barely did after leaving the car sit for a while.
    next, there are four bolts that hold the fuel rails down. they are located on the brackets that are attached to the fuel rail. unbolt all 4 of these. the pics below show the two front, and there are two on the back that look the same.
    after you remove the bolts, you can lift the injectors out of their housings, and begin the UIM bolt removal like below. the fuel rails just pop out. you have to give it some force, but they should come out relatively easily. i just gave a quick yank at the angle they appear to be laying and it worked just fine for me.
    in the next picture, note that i had already removed one of the bolts, it is where you can see a hole. that one is a longer bolt than the others. keep that in mind for reinstallation.
    keep removing the bolts!
    all in all, you should have 7 regular UIM bolts, and then 3 longer ones that connect through the TB (i think), and two other places. just remember where they all go. it's not complicated. here is a pic of all my bolts.
    next is to lift the UIM, and remove the stock runners and gasket. the gasket is clipped to the UIM, so you have to kind of set it down and release the clips and then lift the UIM off.
    stock runners out...
    these are the clips that i had to dremel off. if your car doesn't have them, don't do anything with the gasket...
    dremeled...
    i was unable to get a picture of the hv3 in the UIM, but there is only one way it will fit up into the channels.
    make sure the gasket matches up with the LIM, and then bolt it all back down in reverse order. now is a good time to anti-seize the bolts. you don't have to but it is a good idea.
    once the UIM is bolted back down, i slid the injectors back into their respective housings, and bolted the fuel rail down with the four bolts.
    reconnect your connectors that you disconnected.
    plug in your #2/#4/#6 plug wires on the coil pack.
    reconnect your air filter and maf setup including pcv valve.
    reinspect everything, wires/connectors/bolts, etc.
    fire it up and enjoy your new mod!
  2. #2 Re: hv3 install
    Chilliwack BC
    nice writeup! i assume this is to remove restriction in the intake? maybe a project for next weekend .
    oh and one question, wouldn't you pull the fuel pump relay and start the car to get the fuel out of the rail to be safe? correct me if im wrong but did you leak any fuel when pulling the injectors?
  3. #3 Re: hv3 install
    just press the needle in the schrader valve to release pressure. takes 2 seconds.
  4. #4 Re: hv3 install
    Chilliwack BC
    thanks. i'm mechanically inclined...well...i know enough to get myself into trouble, and everything i've learned is by experience or reading on mitchell.
  5. #5 Re: hv3 install
    Jul 2008
    Tampa, FL
    schrader valve...learn something new every day!
  6. #6 Re: hv3 install
    May 2008
    Winnipeg, MB
    you Sir are a God, I have to get this mod done myself and now from the looks of this write up I may actually be able to do this myself.
    just so happens I'm leaving for Mexico tomorrow or else I would do it this weekend.
    2007 Pontiac Grand Prix
  7. #7 Re: hv3 install
    Grand Island, Nebraska
    Nice writeup, wish every write up was like this. I didnt release the pressure in my fuel rail when i did it and nothing happened, but i would recommend it anyway.
  8. #8 Re: hv3 install
    Jul 2008
    Tampa, FL
    Quote Originally Posted by tod1d View Post
    so are you ordering your hv3 insert then? i'm starting to think that i should have taken a pic of the hv3 in there bc i'm afraid people are thinking that you just remove the runners and bolt it all back down...
  9. #9 Re: hv3 install
    May 2008
    Winnipeg, MB
    I have had the hv3 since Christmas
  10. #10 Re: hv3 install
    Jul 2008
    Tampa, FL
    ok, just wanted to make sure . feel free to PM me if you run into any issues with the install and i'll be sure to add them!
  11. #11 Re: hv3 install
    May 2008
    Winnipeg, MB
    I will hopefully try the install after April 10th when I get back from Mexico, still need an extension for the socket wrench. Maybe even have to cut the clips on the gasket.
  12. #12 Re: hv3 install
    Pennsylvania
    This is a really nice write up, simple and directly worded... and pictures are essential sometimes... I cant tell you how many times I've read through an all-text how to, and gotten to 1 step that just doesnt click in my head and if only there was a picture of it...
    Cant wait to do my hv3 sometime this summer.
    How did it feel? What was your experience after you installed it? Faster? Loss of low end power at all? Even powerband, or just pull hard after x rpms? Any sound difference comin from the engine?
  13. #13 Re: hv3 install
    Jul 2008
    Tampa, FL
    eh, i feel like i lost a tiny bit of low end, but i lost a lot of that with my headers, so idk how that changes it. when i'm cruising at 35 and hammer it, it definitely pulls much harder. accelerating on the highways are stupid now. huge difference. overall, i like it, but i'm definitely still craving more speed. saving for my top swap now. slight sound difference. just sounds like there is a full air sound. some people compare it to being in a tunnel, but i think it's more subtle than that...
  14. #14 Re: hv3 install
    Nice thread.
    I'm going to be brave and try modding the existing runners.
    Free HV?
  15. #15 Re: hv3 install
    Jul 2008
    Tampa, FL
    Quote Originally Posted by That Canadian Guy View Post
    Nice thread.
    Free HV?
    might as well try it since ur demodding, right? you sir are braver than i...i figured i'd just go with something that works.
  16. #16 Re: hv3 install
    Florida
    its more of a deep roar sound lol at least if you have an intake also.
  17. #17 Re: hv3 install
    Does anyone have an HV3 out of their car?
    If so PM me please.
  18. #18 Re: hv3 install
    May 2008
    Winnipeg, MB
    If so PM me please.
    HV3 not installed? if so thats me or are you looking to buy a used one then I'm not selling mine
  19. #19 Re: hv3 install
    Jul 2008
    Tampa, FL
    yes, he wants an hv3 that is uninstalled so that he can get dimensions off of it to attempt to mod the stock runners. he doesn't want to keep it (i don't think)...
  20. #20 Re: hv3 install
    Donating Users Rust's Avatar
    Jun 2010
    Canada
    Also a good time to pull the injectors and replace the rubber O rings. They can get very brittle.
  1. Aux In Install GP +04
    By JohnnyTwoTimesTwoTimes in forum Audio, Security & Visual Electronics
    Last Post: 08-19-2014, 10:10 PM
  2. HID Install Help.
    By blortz in forum Visual/Body Modifications
    Last Post: 03-14-2011, 11:28 PM
  3. SS M90 install
    By Mikey in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-25-2010, 08:17 PM
  4. big install
    By BoostJunki3 in forum Audio, Security & Visual Electronics
    Last Post: 12-30-2009, 12:25 AM
  5. HUD Install
    By Rather B Blown in forum General Tech Discussion
    Last Post: 11-12-2009, 11:12 AM
