Thread: How To: Install 1.8 Roller Rockers on L67
Page 3 of 3 FirstFirst 123
Results 41 to 60 of 60
  1. #1 Re: How To: Install 1.8 Roller Rockers on L67
    no stickies in the how to section.
  2. #2 Re: How To: Install 1.8 Roller Rockers on L67
    michigan
    so you can put 1.9s on stock springs
  3. #3 Re: How To: Install 1.8 Roller Rockers on L67
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    Quote Originally Posted by 02 monte carlo ss View Post
    yes as long as you dont shift past 6000 rpm
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  4. #4 Re: How To: Install 1.8 Roller Rockers on L67
    GTX Level Member real diehl's Avatar
    Salina, KS
    I wouldn't. People have though.
    Quote Originally Posted by nascartech View Post
    Why bother? If you're doing it all you might as well do it right.
    signature removed for inappropriate content.
    -bio
  5. #5 Re: How To: Install 1.8 Roller Rockers on L67
    Quote Originally Posted by realdiehl View Post
    x2 i always like to be safe best to do springs
    sold 97 GTP stock
    michigan
    why would you have to upgrade springs?
    who makes a set of cheap springs for it
  7. #7 Re: How To: Install 1.8 Roller Rockers on L67
    Minnesota
    Gmpartsdirect.com Part# 12589774
    Those are L92 springs. You will need different retainers to get the correct height though IIRC.
    michigan
    what retainers would i need
    so er rocker arms from zzp those springs and retainers? would i need push rods to?
  9. #9 Re: How To: Install 1.8 Roller Rockers on L67
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    no you dont need push rods
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
    michigan
    would you happen to know what retainers id need?
    those springs will work with the rocker arms? and where do i get the retainers for the springs
    ZZ Performance
    would these retainers work
  11. #11 Re: How To: Install 1.8 Roller Rockers on L67
    making a new post every hour wont get you answers quicker.
    those will work.
  12. #12 Re: How To: Install 1.8 Roller Rockers on L67
    Minnesota
    When you order or if you order those springs off GMpartsdirect you are going to have to order 15 since they come in packs of 5. Just to let you know. Or you can try to find someone who has bought them already and has two extras.
  13. #13 Re: How To: Install 1.8 Roller Rockers on L67
    michigan
    just trying to get other peoples opinions thanks though
  14. #14 Re: How To: Install 1.8 Roller Rockers on L67
    GT Level Member GreyGhost's Avatar
    Nov 2009
    IL
    I am confused. I thought this 3.8 the rockers were held on with studs not pedestal mounted.?.?.? Which is it?
  15. #15 Re: How To: Install 1.8 Roller Rockers on L67
    there are bolts that hold the rockers to a pedestal to the head.
  16. #16 Re: How To: Install 1.8 Roller Rockers on L67
    SLP, GTP or call it MUT! thunder71173's Avatar
    West Frankfort Illinois
    Man I wish I would have known the 25 ft lb number for reinstalling the rockers when I was putting my L67 together. The gm specs are 11 ft lbs plus 90 degrees! ouch I thought they were gonna break!
  17. #17 Re: How To: Install 1.8 Roller Rockers on L67
    GM's just crazy period.
  18. #18 Re: How To: Install 1.8 Roller Rockers on L67
    how bout the head bolts 37 ft lbs plus 120 deg! I know it has to be close to 120 ft lbs!
  19. #19 Re: How To: Install 1.8 Roller Rockers on L67
    well studs are 90 ft lbs.
    but for certain years GM called for an additional 30* on the inner four bolts.
  20. #20 Re: How To: Install 1.8 Roller Rockers on L67
    Pennsylvania
    Sorry for the old thread, but Im workin on this now and I need help before I go further.
    I got the fronts done, workin on the back now, got the valve cover loose but it wont come out. I've been told by many people that the alternator doesnt need to be removed, and the tensioner assembly with the coolant elbows doesnt need to be removed... and none of that is listed in this howto... he even shows a pic with the rear vc off and the alternator in place, but I just cant seem to get an angle that the valve cover will wiggle out.
    Is it possible do finish the job without pulling the coolant elbows and tensioner assembly out? A lot of people said I dont need to... It's an l32.
    Sport Edition Kv5 18x8
  1. roller rockers ?
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2008, 12:28 PM
  2. Roller Rockers
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2008, 05:49 PM
