Thread: 97-02 Parts List
Results 1 to 5 of 5
noreasonwhyy 97-02 Parts List 06-08-2010, 08:32 PM
PurpleGuy Re: 97-02 Parts List 02-21-2012, 12:22 AM
matt5112 I'll move it to how to 02-21-2012, 07:54 PM
PurpleGuy Re: 97-02 Parts List 02-21-2012, 10:33 PM
Wraith888 Re: 97-02 Parts List 06-24-2013, 09:34 AM
  1. #1 97-02 Parts List
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    Here's a parts list for 97s to 02s I found a while back. Some parts have been replaced by newer part numbers for the 04+, but the gmpartsdirect catalog should point you in the right direction. Also, some parts are no longer produced. Hope this helps someone out!
    Engine Parts
    AC Delco Fuel Filter GF-578 25121293
    PCV Valve CV-892C for a (L67) 25043843
    PCV Valve for a (L36) 3.8L V6 17113515
    PCV Valve for a (LG8) 3.1L V6 25043843
    PCV Valve Gasket 24503777
    PCV Valve Seal-O-Ring 25534756
    Goodyear Gatorback Supercharge Poly V Belt (for 3.4" - 3.25" Pulley) 4060660
    Goodyear Gatorback Supercharge Poly V Belt (for 3.1" - 2.9" Pulley) 4060650
    Goodyear Gatorback Supercharge Poly V Belt (for 2.7" - 2.85" Pulley) 4060642
    Goodyear Gatorback Serpentine Poly V Belt for '98 4060935
    Goodyear Gatorback Serpentine Poly V Belt for '99 4060915
    Power Steering Pump 02650488
    Power Steering Hose 26064185
    Coolant Overflow Hose for '99 Coolant Overflow Bottle 10291659
    Flywheel for (L67) 24505216
    Flywheel for '97 GT or SE with the (L36) 24508110
    Starter Motor 10465309
    Supercharger Gasket (L67) 24503911
    Intake Manifold (L67) 24505729
    Intake Manifold Gasket for a (L67) 12480880
    Intake Gasket Kit with Plenum (Upper Intake) Gasket (L36) 17113137
    Intake Manifold Gasket for a (L36) 12537197
    Driver's Side Lower Transmission/Engine Mount 22178939
    Passenger Side Lower Engine Mount 22175206
    Upper Motor Mount Bracket (Same for Driver and Passenger) 10271462
    Upper Motor Mount Bolt 11516666
    Upper Motor Mount Nut 10255857
    Tensioner for a (LG8) 3.1L V6 24507685
    3.5 Idler Pulley (Upgrade Tensioner Pulley) (L67) 24506756
    Drive Belt Tensioner 24502989
    Supercharge Drive Belt Tensioner 12564506
    Accessory Belt Tensioner (L67) 24504818
    Supercharger Fill Plug '97-'01 (L67) 24500661
    Fuel Rail Assembly for a '00-'02 (L67) 24508941
    Fuel Injectors (L67) 24508208
    Fuel Injector Metering Retainer (Fuel Injector Clips) 24503227
    Vacuum Line Assembly (L67)(Complete Kit) 24507329
    Vacuum Line Assembly (L67)(from TB) 24506665
    Engine Camshaft & Valve Rocker Hardware (Left Valve Cover) 24503935
    Engine Camshaft & Valve Rocker Hardware (Right Valve Cover) 24503936
    Valve Cover Gasket 24503937
    Valve Lifter (8 Pack) 17122490
    Water Pump Pulley 12537829
    Water Pump Pulley (LG8) 14091833
    Head Bolt (short) (L67) 25527831
    Head Bolt (long) (L67) 25533811
    Head Gasket Set (Head, Intake, Valve covers) (L67) 12539091
    Harmonic Balancer 12563268
    Engine Oil Pan (L67) 12563240
    Engine Oil Pan Gasket (L67) 12574776
    Engine Piston (L67) 12539085
    Engine Piston Ring Kit (L67) 12480825
    Engine Valve Rocker Arm (Stock 1.6:1 Rockers) (L67) 24503999
    Engine Valve Adjusting Support Bold (5 Pack) 24503515
    Rocker Support Retainer 24502278
    Rod Bearing 12480819
    Engine Coolant Outlet Gasket 24502433
    Water Pump Pulley (L67) 24507524
    Cylinder Heads (L67) (1997-1998 Old Castings .855" valve spring seat pilots) 24503436
    Cylinder Heads (L67) (1998+ New Castings .810" valve spring seat pilots) 24507848
    Intake Parts
    Air Intake Hose Including IAT Sensor for '99-'00 24507362
    MAF/Throttle Body for a '01 (L67) 24507241
    MAF/Throttle Body for a '99-'00 (L67) 24503396
    MAF/Throttle Body for a '97-'98 (L67) 24503395
    MAF/Throttle Body Screen for '97-'98 (L67) 24503677
    MAF/Throttle Body Stud for a '97-'02 (L67) 24504462
    Multiport Fuel Injection Throttle Body Seal (Gasket) 24503648
    GM Under-Hood Radiator Air Deflector '99-'00 10419842
    Cooling System
    Coolant Overflow Hose for '99-'01 10291659
    Heater Core 52465600
    Robert Shaw 180° Thermostat 457180
    Robert Shaw 160° Thermostat 457160
    Thermostat Gasket for '97-'98 25535214
    Water Pump for a (L36) & (L67) 12537829
    Water Pump for a (LG8) 12518295
    Radiator Air Deflector/Baffle for '99-'00 10442031
    Radiator Air Deflector/Baffle for '01-'02 10423208
    Coolant Reservoir Bottle from '99-'02 10423219
    Transmission Parts
    Part Descriptions Part Numbers
    4T65E 1-2 piston spring for 4T65-E Transaxle (MN7) 24203976
    4T65E 2-3 piston spring for 4T65-E Transaxle (MN7) 24203977
    1-2 or 2-3 Accumulator piston 24206857
    1-2 or 2-3 Accumulator piston pin 24203979
    Accumulator Seal kit 24206959
    Accumulator, cover 24211955
    Filler Tube 4T65E 12562853
    Transmission Pan 24206181
    Transmission Pan Gasket for 4T65-E Transaxle (MN7) 24206182
    Retaining Clip (E-Clip Holds Transmission Cooler Lines in at Radiator) 24205103
    Carrier (Differential) for 4T65-E Transaxle (MN7) 24208455
    AC-Delco Transmission Filter Kit for 4T65-E Transaxle (MN7) 24206433
    VSS Reluctor Wheel 24202393
    Electrical Parts
    Inlet Air Temp Sensor (IAT) 12160244
    Driver Side Headlight Assembly 16530417
    Passenger Side Headlight Assembly 16525774
    Head Light Bulb 9007
    High Mount Brake Light Bulb 1141
    Driver Side Headlight Capsule 16522599
    Passenger Side Headlight Capsule 16522600
    Drivers Side Taillight 5978571
    Passenger Side Taillight 5978572
    Passenger Side Turn Signal Lens Assembly 16522198
    Drivers Side Turn Signal Lens Assembly 16522197
    Driver Side Parking Turn Signal Lamp 16521834
    Passenger Side Parking Turn Signal Lamp 16521833
    Daytime Running Lights Diode 15043231
    Heads Up Display (HUD) 9364292
    Heads up Display (HUD) switch 10402058
    Digital Dual-Zone Climate Control Unit 9351482
    Window/Door Lock Switch Plate for Coupe (PLT-SW/MT) 10420344
    Window/Door Lock Switch Plate for Coupe (SW-SI/WDO) 10404698
    Keyless Entry Fobs & Batteries 10290246
    Keyless Entry Fobs & Batteries 10246215
    Window/Door Lock Switch Plate for Sedans (PLT-SW/MT) 10420343
    Window Switch for Sedans (Driver Side) (SWITCH AY) 10290244
    Window Switch for Coupe (Driver Side) 10290241
    Headlamp and Dome Light Switch 10249112
    Interior Door Light/Reflector for Coupe 10247551
    Fog Light Switch 10249396
    Fog Light Switch Wire Harness 12125665
    Fog Light Bulb (27watts) 880
    Fog Light Bulb (38watts) 893
    Turn signal Relay 12450054
    Turn signal Switch (switch only) 19005031
    Trunk Lamp w/ Lens 10273135
    Blower Motor Resistor for Manual Controls (Non-Dual Zone) 12135102
    Dielectric Grease for your Plug-Wires 12345579
    Spark Plug Wire Set (7MM Premium Delco) (Replaces P/N: 1219-2071) 12192468
    Spark Plug Wire Set (L67) 12192421
    Spark Plug Wire Set (L36) 12192153
    Spark Plug Ignition Wire Shield Bracket (from a Bonneville) 24507192
    Fuel Pump Resistor 10422108
    Fuel Pump Resistor Kit (Includes: Resistor Zip Tires Wiring Harness) 88951182
    Exterior Temperature Sensor for Electronic Dual-Zone AC 10248414
    GM Under Hood Lamp 10251024
    GM Under Hood Lamp Harness 12116958
    Electronic Spark Control (ESC) Module 16051654
    PCM for a '97 (L767) 16227797
    PCM for a '98-'00 (L67) 16200870
    Crank Position Sensor for a (LG8) 3.1L V6 12550965
    Crank Position Sensor for a (L67) 10456161
    Alternator for '97 GT or SE with the (L36) 3.8L V6 10464075
    Power Window Driver Side Regulator/Motor 10413609
    Heated Seat Switch 10416900
    Harness for Power Seat 6-pin 12173255
    Power Seat Switch 6-way 16788714
    Fan/Ignition Switch 26068757
    Alarm Module Package should fit most GP's with keyless entry 12463357
    Alternator (Replaces P/N: 10463966) 10464075
    Mass Air Flow Sensor (AC Delco P/N: 213-301) (L67) 24505519
    Harness for Door Panel Light 12085535
    Harness for Seat Heater Switch 15305927
    Mass Air Flow Sensor 24505519
    Starter (L67) S/C 3.8L V6 GTP 10465309
    Keyless Entry Fobs Battery 12538938
    Knock Sensor (Rear) Harness Connector 12101763
    Trunk Latch with Remote Solenoid 10304039
    Delco Audio Amplifier (NON Bose) 9378542
    Chevrolet Impala (POLICE 9C1 / 9C3) / (TAXI 9C6) 125 Amp Alternator Upgrade
    125 Amp Alternator 10288764
    DIC for '97 SE/GT (1st design, built before VIN 238198) 16234952
    DIC for '97 GTP (1st design, built before VIN 238198) 16234942
    DIC for '97 SE/GT (2nd design) 16249182
    DIC for '97 GTP (2nd design) 16249192
    DIC for '98 SE/GT 16268412
    DIC for '98 GTP 16268422
    DIC for '99 GTP 9360342
    DIC Cover Panel with out Traction Control Button 16203865
    DIC Cover Panel with Traction Control Button 16200975
    DIC Bulbs 16151234
    Interior Parts
    Dash Retainers Clips 10410321
    Upper Dash Cover Panel Alarm Led/Temp Sensor/Light Sensor 10402885
    Instrument Cluster Lens 16213444
    Door Panel Retainers Clips 10285935
    Heavy Duty Door Panel Retainers Clips 10153057
    Rear Seat Retainers 16809855
    Center Console Inner Liner & Coin Holder 10439382
    Center Console Inner Liner 10212199
    Coin Holder 10436137
    Steering Shaft 26057715
    Front Seat Release Handle for Passenger Side Coupe 16705815
    Front Seat Release Handle for Driver Side Coupe 16787419
    Passenger Seat Skirt (Plastic Part) 16793071
    Plastic Retainer Clip for Rear Seats 16809855
    Leather Shift Knob with performance shift button (Graphite) 12559928
    Leather Shift Knob with out performance shift button (Graphite) 10224210
    A-Pillar Molding 10294524
    Heads up Display (HUD) Dash Panel (Graphite) 10403050
    Heads up Display (HUD) Dash Panel (Neutral) 10403056
    Heads up Display (HUD) Clip 21040288
    Heads up Display (HUD) Retainer 22547243
    Coin Compartment (Left and/or Right Side of Steering Wheel) 10253332
    Dash Bezel (Graphite) 10422488
    Driver Lumbar Support Knob for '97 16787419
    Passenger Seat Belt Retractor (Does NOT Include Buckle Side) 12455727
    Carpet Front Floor Mats (Graphite) 12365644
    Carpet Rear Floor Mats (Graphite) 12365647
    Carpet Front Floor Mats (Neutral) 12365646
    Carpet Rear Floor Mats (Neutral) 12365649
    Carpet Front Floor Mats (Oak) 12371459
    Carpet Rear Floor Mats (Oak) 12371460
    Custom Vinyl Front Floor Mats (Graphite) 12495240
    Custom Vinyl Rear Floor Mats (Graphite) 12495232
    Custom Vinyl Front Floor Mats (Neutral) 12495242
    Custom Vinyl Rear Floor Mats (Neutral) 12495236
    Custom Vinyl Front Floor Mats (Gray) 12495241
    Custom Vinyl Rear Floor Mats (Gray) 12495234
    Passenger Side Heater/AC Accumulator '97-'00 16163982
    Passenger Side Heater/AC Accumulator '01-'02 16177412
    Exterior Parts
    Hood (Stock) 12369173
    Roof Hard Cargo Carrier ( Long, Black, Textured Finish (Four-Door Only)) 12495606
    Roof Hard Cargo Carrier ( Long, Graphite, Smooth Finish (Four-Door Only)) 12495607
    Roof Hard Cargo Carrier ( Short, Black, Textured Finish) 12495608
    Roof Hard Cargo Carrier ( Short, Graphite, Smooth Finish) 12495609
    Roof Mound Ski Carrier (Four-Pair) 12495611
    Roof Mound Bicycle Carrier (One Bicycle) 12497223
    Roof Rack for Roof Hard Cargo, Bicycle, Ski Carrier (Required) 12495560
    Pontiac Arrowhead Crest (Front) 20696860
    GTP Badge 10246507
    Chrome "Grand" Badge 10246503
    Chrome "Prix" Badge 10246504
    GT/GTP Front Fascia for '98-'00 10292116
    GT/GTP Rear Bumper Cover '98-'00 10299771
    GP/GTP Stock Spoiler for '97-'00 12495073
    Front Fascia Emblem (Arrow) 20696860
    License Plate Attaching Parts (GT & GTP Style) 6270119
    Silver GTP Badge 10246507
    Red "GT" Badge 10255634
    Drivers Side Front Fascia Grille for '97-'02 10283641
    Passenger Side Front Fascia Grille for '97-'02 10283640
    Wheel Well Liner Rear Driver Side 10444668
    Wheel Well Liner Rear Passenger Side 10444669
    Passenger Side Outside Mirror 10424657
    Splash Guards w/Grand Prix logo 12371110
    Passenger Side Rocker Molding of Coupe 12455147
    Trunk Compartment Lid (NO Spoiler) 12527727
    Trunk Strut 10414234
    Trunk Latch 10304039
    GM Trailer Hitch (1 7/8" Ball) 12495780
    GM Trailer Hitch (2" Ball) 12495784
    GM Trailer Hitch for GT/GTP 12496830
    GM Trailer Hitch for SE 12496832
    Subframe 10424591
    Wheel Parts
    Black Wheel Center Cap with Pontiac Arrowhead Symbol for '99 9593883
    Silver Wheel Center Cap with "PONTIAC" Circles the Cap 9593444
    GM Keyed Wheel Lock Set '97-'98 ( plastic caps fit on these) 0999057
    Lug Cap '97-'98 (Black plastic) 9593228
    Lug Nut (5 Pack) 10194314
    Stainless Steel Lug Caps (10 Pack) 9593175
    Oldsmobile Intrigue (Autobahn JA9) Spare Wheel for 11.9" Rotors (16" x 4") 9593686
    Wheel Stud (Stock Length Wheel Stud) 9598498
    Wheel Stud (Shorter Wheel Stud than Factory) 9590476
    Driver Side Front Hub Bearing Kit 07470017
    Bearing/Hub Assembly 1st design with Stainless Steel Clip for ABS Sensor Plug for '97 - '00 12429204
    Bearing/Hub Assembly 2nd design with plastic clip for ABS sensor plug for '01 - '02 12429205
    Hub Bolts (5 pack) These are the three "shoulder" bolts that hold the hub in (single-use only) 18022052
    Fluids
    Top Engine Cleaner (Top End Cleaner) 1050002
    GM Supercharger Oil (4 FT. OZ.) 12345982
    EOS - Engine Assembly Pre-lube (16 oz) 1052367
    Power Steering Fluid (1 Quart) 1050017
    Power Steering Fluid (16 FT. OZ.) 1052884
    Suspension Parts
    GTP Factory Rear Sway Bar 14mm 10284147
    Rear Sway Bar Links 10413928
    Steering Rack Gear Kit 6.508 26031079
    Inner Tie Rod 26021769
    Outer Tie Rod 26086579
    Rear Sway bar links 10413928
    Olds Intrigue Rear Springs (Approx. 3/4" Boost in the Rear) 10421038
    Energy Suspension Polyurethane Sway Bar Bushings 9.5164R
    Energy Suspension Polyurethane End Link Grommets 9.8105R
    Heavy Duty Coil Springs (Fits all 4 Corners) 10258880
    Front Control Arm Bushing 10260991
    Rear Control Arm Bushing 10255029
    Front Upper Strut Mounts 22179011
    Strut Mount - Driver Side Rear 10410961
    Strut Mount - Passenger Side Rear 10410962
    Chevrolet Impala (POLICE 9C1 / 9C3) / (TAXI 9C6) Sway Bar Package
    Set Part Descriptions Part Numbers
    1-3. Front Sway Bar 10404184
    2-3. Front Bushings x2 10403188
    3-3. Front Bracket x2 10294949
    1-3. Rear Sway Bar 10274610
    2-3. Rear Bushing x2 10415925
    3-3. Rear Bracket x2 10257809
    Exhaust Parts
    GM Rubber Exhaust Hangers Insulator 10231659
    Exhaust Manifold Gasket 24506057
    Exhaust Gasket 2.5" for Catalytic Converter to Resonator 10275205
    Exhaust Gasket Between the Exhaust Manifold and Down Pipe 12565634
    Exhaust Manifold Studs for a '97-'02 (L76) S/C 3.8L V6 24502332
    Driver Side Exhaust Tips 10243867
    Passenger Side Exhaust Tips 10243868
    Corsa Catalyst Back Exhaust System 12498617
    Brake Parts
    ABS Jumper Wire 12144686
    Brake Caliper Front Driver Side 18024956
    Brake Caliper Front Passenger Side 18024957
    Brake Caliper Rear Driver Side 18029935
    Brake Caliper Rear Passenger Side 18029936
    OEM Stock Front Rotors 18021359
    Front Caliper Brake Bolt 18024960
    Delco Front 10.4" Cross-Drilled and Slotted Rotors 18038816
    OEM Stock Rear Rotors 18021354
    Rear Caliper Bracket Bolt 18023389
    Rear Caliper Pin Bolt 18029933
    Rear Guide Pin Bushing Set 18029934
    Delco Rear Cross-drilled and Slotted Rotors 18038815
    Rear AC Delco Durastop Ceramic Brake Pads 88909660
    GM Rear Brake Pads 18029844
    Miscellaneous Parts
    Key Blank (PK3M) 88951932
    Key Blank, Pass Key III, Valet 02852330
    Hood Struts 10401309
    GTP Engine Cover (Shield) for '97-'01 GTP 24505882
    GT Engine Cover (Shield) for '99 GT 12565395
    Stock engine cover nut 11514596
    Windshield with (HUD) Tinted 10302619
    Bose Speaker Grills for Front Doors 1175962
    Vent Visors (Two-Door, Smoke) 12495058
    Taillight/Trunk Net "clips" (NUT-WING) 10079160
    Engine Oil Dip Stick (Yellow) 12574823
    Blank Key (PASS Key III, valet) 2852330
    Blank Key (PASS Key III) 88951932
    Suburban/Tahoe Rear View Mirror with Outside Temp & Compass 15031606
  2. #2 Re: 97-02 Parts List
    Never Never Land
    Maybe a mod could copy and paste this into a similar thread that's stickied?
  4. #4 Re: 97-02 Parts List
    Never Never Land
    Thank ya sir...I thought it was pretty useful.
  5. #5 Re: 97-02 Parts List
    SE Level Member Wraith888's Avatar
    Twin Cities
    I believe it should be 10408480 for 98 and later and 10153057 for '97 for the "Heavy Duty Door Panel Retainers Clips 10153057" part
  1. interchangable parts list
    By Mayja in forum Brakes/Suspension/Chassis
    Last Post: 05-29-2010, 09:50 PM
