Thread: Modifying KYB Struts to Work with Coilovers.
Results 1 to 3 of 3
  1. #1 Modifying KYB Struts to Work with Coilovers.
    GT Level Member pontiackid's Avatar
    KCMO
    This write up can really be applied to any stut made for our cars but, in this case I wanted to have maximum control over every aspect of my suspension that I could. What better way than to have instant height adjustment through coilovers and stiffness through the KYB AGX 4-Way Adjustable Struts.
    :WARNING:
    This involves some dangerous equipment if used incorrectly so as always, safety first. Also note after doing this mod, if you screw up it is not my fault and you can easily ruin your struts. Finally this is to get them to work with coilovers, so in the event you want to switch back to a regular spring/strut setup, you will need to replace your struts. $$$
    (PS if your wondering why its all fancy looking, I also originally did this for the owner of HT/Held Motorsports for his site...)
  2. #2 Re: Modifying KYB Struts to Work with Coilovers.
    Aug 2008
    KCMO
    so how good is the ride with coilovers?
  3. #3 Re: Modifying KYB Struts to Work with Coilovers.
    KCMO
    Depends on what springs you order sorta, I mean mine will always be rough as I have 400lbs in the rear for the track but, with that I can fine tune the stiffness/slack with the AGX's... Can't say much as I had them in for maybe 2 weeks before my motor blew.
  1. 97-98 struts vs 99-03 struts
    By joshua_arndt in forum Brakes/Suspension/Chassis
    Last Post: 01-15-2010, 02:44 PM
  2. WriteUp: Modify Strut to work with Coilovers.
    By pontiackid in forum Brakes/Suspension/Chassis
    Last Post: 04-29-2009, 02:02 PM
  3. coilovers
    By 98GPGT in forum General Tech Discussion
    Last Post: 10-18-2008, 01:56 AM
  4. HELD Coilovers Installed!!
    By JashGTP in forum Visual/Body Modifications
    Last Post: 05-17-2008, 12:46 AM
  5. kyb struts
    By johnnyj773 in forum Brakes/Suspension/Chassis
    Last Post: 05-12-2008, 02:08 PM
