Sorry i thought that the links worked. here are the pics. the first i used 1/2" or 5/8" copper pipe that was closed on one end. i cut notches in it so that i could put a screw thru it to lock the now knob on it. i had too sand the pipe down some so that the knob would fit over it. the next pic shows the difference in the shift linkage. i removed the plastic rod and made a new one out of 1/4" aluminum bar i had around. it rattled some so i later put some electrical tape around the rod to soften the rattle. if your using a stock type knob you will need to cut a new slot in the linkage and the notches for the pin/ clip.
