Thread: How to paint your FWI.
Results 1 to 9 of 9
Bogers99GTP How to paint your FWI. 04-26-2009, 07:42 PM
Sabrewings Re: How to paint your FWI. 04-26-2009, 09:01 PM
Bogers99GTP Re: How to paint your FWI. 04-26-2009, 09:44 PM
grand2000prixgtp Re: How to paint your FWI. 04-26-2009, 10:03 PM
Bogers99GTP Re: How to paint your FWI. 04-26-2009, 10:14 PM
GTPJOE90 Re: How to paint your FWI. 04-27-2009, 06:04 PM
stlmo_gtp Re: How to paint your FWI. 04-27-2009, 06:50 PM
jacobmh27 Re: How to paint your FWI. 06-11-2009, 09:13 AM
Bogers04SS Re: How to paint your FWI. 02-24-2010, 03:49 PM
  1. #1 How to paint your FWI.
    Donating Users
    W-S, NC
    Ive had a few requests awhile back on how to paint intakes, dogbones and so on. So ive taken many pics so I can show how to turn a ugly piece of PVC pipe
    and make a nice looking intake.
    First take you piece of PVC and clean it very well. Greased Lightning, 409 (I used carb cleaner on this project). After you clean it good, then wash off the cleaner and dry the PVC off. Make sure there is no water left on it.
    Then take some 800 grit sandpaper, sand the entire outside of the PVC till you see a film of dust appear on the pipe. Take the pipe and wash it off, making sure all the dust and dirt is off the pipe.
    When your done with this you'll be tired of cleaning lol. Once the pipe is fully clean, its time to paint. Depending on thetype of paint you may have to usea base coat of paint. I used the Metalcast red which needed a base coat to make it look right.
    Take the can of spray paint and shake it for a full minute or 2. Start from the top of the pipe and sweep up and down slow but not at a creep. Make 2 passes. Keep doing this all the way around the pipe. Let the paint dry for 2 mins. Repeat the process 3 more times. If you need to do a base coat for your type of paint, then the same steps but only do enough to cover the pipe.
    Let the paint dry for at least 30 mins to a hour before handleing it. If not then youll see what your fingerprints look like. Check for any light spots, if you see any then apply a light coat to cover up the light spot.
    Take the pipe install into the engine bay.
    Stand back and smile!
    This is the one I did on my 99 GTP.
    Any questions....feel free to ask!
  2. #2 Re: How to paint your FWI.
    Barksdale AFB, LA
    Sure is a nice looking car...
    2009 Subaru Impreza WRX STI
  3. #3 Re: How to paint your FWI.
    Donating Users
    W-S, NC
    Quote Originally Posted by Sabrewings View Post
    Thanks Sabre...I did some work on my grille to. I'll have to post it up later tonight
  4. #4 Re: How to paint your FWI.
    GT Level Member grand2000prixgtp's Avatar
    Grayslake
    how do u paint the dogbones
  5. #5 Re: How to paint your FWI.
    Donating Users
    W-S, NC
    Quote Originally Posted by grand2000prixgtp View Post
    The easiest way is to sandblast them or glass-bead them in a blasting cabinet. If not, sand all the old paint off and use the same process as I did with the PVC. If you use sand paper, use 220 to 400 grit, just use the 220 lighter than the 400 because it will eat away at the metal.
  6. #6 Re: How to paint your FWI.
    May 2008
    McHenry IL
    ncie prep work prep is what makes the paint so fabulous =]
  7. #7 Re: How to paint your FWI.
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    nice job, looks really good
  8. #8 Re: How to paint your FWI.
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    that FWI you have there looks like the easyest one ever I think that I will build that on is that just a cone on the end of a pice of PVC what size filter is that
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  9. #9 Re: How to paint your FWI.
    GT Level Member Bogers04SS's Avatar
    Feb 2010
    Mocksville, N.C.
    Quote Originally Posted by jacobmh27 View Post
    not sure on the size of the filter, its the medium size one you can get from AutoZone. The PVC pipe is 3in.
    04 Impala SS -- SOLD
    08 Prix GXP -- FWI, 3in DP, TR6IX plugs, Ported & polished throttle body, ported intake manifold, DiabLEW Tuned, wrapped crossover pipe, Cat delete, Factory res., Muffler delete, Poly motor mounts, shift kit, LED bulbs in just about every Da*n thing, ect..
  1. Paint job
    By jaysongt85 in forum Detailing Tips and Tricks
    Last Post: 10-27-2009, 12:09 PM
  2. touch up paint
    By TheOtherNick in forum Visual/Body Modifications
    Last Post: 01-09-2009, 08:16 PM
  3. Want to paint dogbones
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2008, 10:56 AM
  4. Need Paint Advice
    By JJ91284 in forum Visual/Body Modifications
    Last Post: 09-30-2008, 08:43 PM
  5. Paint codes
    By Orbital431 in forum Visual/Body Modifications
    Last Post: 06-27-2008, 02:03 AM
