Thread: Repair Your Power Windows Switch[*]
Results 1 to 20 of 47
  1. #1 Re: Repair Your Power Windows Switch[*]
    Highland Heights, KY
    unless you mean the complete switch on the drivers side but its new..... and the window still occasionaly works...
    do you know what wires i can hot wire or splice into to check the rear passenger motor. I need this fixed got the know how but need an idea where to start
  2. #2 Re: Repair Your Power Windows Switch[*]
    Jan 2009
    Mexico
    Where is the description? Any photos?
  3. #3 Re: Repair Your Power Windows Switch[*]
    OK here is my problem I fixed it. The connector that snaps on the switch. The female ends in the connector that the male ends on the switch slide in to are spread out. TO FIX. I used a small nail and pushed them together. So now the male ends that slide in to the female are tight...
    MAKE SENSE>
    try this..
    Try pushing the window button that IS NOT working and move teh connector around that mounts to the underside... Thats how i figured it out
