Thread: Repair Your Power Windows Switch[*]
Results 1 to 20 of 47
  1. #1
    Taylor,MI
    My driver side window was doing the very same as described above. I had a radio/speakers installed today and i guess something finally crapped out while they were putting it all back together as they could not get the window back up. They called me back to their garage and i messed with it with them. Anyways, now it won't even budge anymore. Usually i just had to fiddle with it for a minute and let it go up in its spurts, now nothing. The guy that was installing it did like pictured above with putting the "prob" on the wires to try to bypass the switch or whatever. This did not not get the window to move either. I'm assuming this means the motor is shot? Also, the motor feels pretty hot.
    Port Hope Ont,Canada
    Did he try both Blue wires ?
    one is for up the other is for down ....
    if this does not work then yes the motor is shot
    for sure... hope it was just the wrong button he had the wire on...
    Good luck with the repair Rob
    John
    Taylor,MI
    Where can i get the little "rocker" or whatever at to replace it? Maybe I'll take the switch apart and see what the tips look like and just replace them even if it is the motor since it seems to be a commen issue and the car is now almost 9 years old with 124k miles.
    As for which wires he messed with, i honestly didn't pay attention or think about it at the time. The window was all the way down, so if he was messing with the down wire that would certainly explain it doing nothing.
    I went to a local salvage yard to see if they had any motors there for cheap. They did, but they already had it out of the car (so i didn't get to see where exactly it came from). The guy tells me it came out of the front door of a 99 four door (which is what if have) however after taking out my old motor/regulator the bracket that connects to the window was slightly different on the two. The one he gave me was slightly shorter and where the screws go in was angled slightly different. My guess is that the one he gave me was from the back left door or something. Stupid me didn't check to make sure they were exactly the same before hand and after getting frustrated with why bracket and window wouldnt line up just right i figued out the bracket had to be different. While messing with it i did flip the switch to see if it did anything and it did seem like it was trying to move the window.
    Maybe I'll just go ahead and replace both since the old motor/regulator are already out, and i plan on keeping the car for a while and it will probably go out eventually anyway.
    Anyway, thanks for posting up how to fix the switch, certainly saved me a lot of time trying to figure it out.
  4. #4 Re: Repair Your Power Windows Switch[*]
    Sep 2012
    San Diego
    What do you jump the blue wires to? I'm not sure if they're for ground, or for power. The write-up won't open for me.
