BillBoost37
That may have come off as a bit harsh, sorry ... didn't realize it sounded that way. I had merely meant there are much worse out there for blow by. We drew the lucky card.
Nice on that check. Interesting tidbit, the map reads manifold pressure and by doing so it is a possible culprit when you get EGR codes like P0406 insufficient flow. Technically it's the MAP not seeing a change when the EGR is commanded open. We've seen a few folks who didn't fully understand the workings and ended up replacing a $150 egr more than once w/o any change.
Who doesn't like having trouble finding the hidden bolts because they are under 1-2 inches of oil? hahaha
