Thanks bill, I know the rings don't wear much, what I was referencing is that the pcv itself tends to suck up oil. I'm not talking about a bunch, but enough to coat the inside of your intake over 200,000 miles (I'm sure you've seen your fair share). Not saying that this is by any means a necessary mod (unless you go really high on boost), but it might keep your engine and oil cleaner in the long haul.
I t-d off of the evap vacuum source (eventually I'll be relocating it to the rear of the engine). Now it won't get oil spewn all over it like where it was originally positioned though. And yes, I did a graphical analysis of the readings both in the original location and on the evap vacuum, and they are identical.
