Thread: L67 Mechanical Specs
Results 1 to 12 of 12
  1. #1 L67 Mechanical Specs
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    Metric English
    General Data
    • Engine Type 90° V-6
    • Displacement 231 cu in
    • Liter (VIN) 3.8L (K), (1)
    • RPO L36, L67
    • Bore 96.52 mm 3.8 in
    • Stroke 86.36 mm 3.4 in
    • Compression Ratio (VIN K) 9.4:1
    • Compression Ratio (VIN 1) 8.5:1
    • Firing Order 1-6-5-4-3-2
    Lubrication System
    • Oil Capacity with Oil Filter Change 4.25 L 4.5 qt
    • Oil Capacity without Oil Filter Change 3.75 L 4 qt
    • Oil Pressure @ Operating Temperature (1850 RPM) Using 10W-30 Oil 414 kPa 60 psi min
    • Oil Filter Type Throw Away Element and Can
    • Gear Pocket Depth 11.71-11.75 mm 0.461-0.4625 in
    • Gear Pocket Diameter 89.10-89.20 mm 3.508-3.512 in
    • Inner Gear Tip Clearance 0.152 mm 0.006 in
    • Outer Gear Diameter Clearance 0.203-0.381 mm 0.008-0.015 in
    • End Clearance 0.025-0.089 mm 0.001-0.0035 in
    • Valve-to-Bore Clearance 0.038-0.076 mm 0.0015-0.003 in
    Type of Lubrication
    • Main Bearings Pressure
    • Connecting Rods Pressure
    • Piston Pins Splash
    • Balance Shaft Bearing - Front Splash
    • Balance Shaft Bushing - Rear Pressure
    • Camshaft Bearings Pressure
    • Timing Chain Splash
    • Cylinder Walls Splash
    • Oil Pump Type Gerotor
    • Oil Pressure Sending Unit Electrical
    • Oil Intake Stationary
    • Oil Filter System Full Flow
    Cylinder Bore
    • Diameter 96.5 mm 3.8 in
    • Out-Of-Round Maximum 0.0254 mm 0.001 in
    • Taper 0.0254 mm 0.001 in
    Piston (VIN K)
    • Used Piston Clearance (41 mm from Top of Piston) 0.050-0.091 mm 0.0020-0.0036 in
    • New Piston Clearance (41 mm from Top of Piston) 0.010-0.051 mm 0.0004-0.0020 in
    Piston (VIN 1)
    • Used Piston Clearance (41 mm from Top of Piston) 0.0193-0.0997 mm 0.0008-0.0039 in
    • New Piston Clearance (41 mm from Top of Piston) 0.0207-0.0437 mm 0.0008-0.0017 in
    Piston Ring Groove Depth
    • Top Compression 4.019-4.146 mm 0.158-0.163 in
    • 2nd Compression 4.214-4.341 mm 0.0166-0.171 in
    • Oil Control 3.814-3.941 mm 0.150-0.155 in
    Piston Ring End Gap
    • Top Compression 0.25-0.46 mm 0.010-0.018 in
    • 2nd Compression 0.58-0.84 mm 0.023-0.033 in
    • Oil Control 0.254-0.762 mm 0.010-0.030 in
    Piston Ring Side Clearance
    • Top Compression 0.033-0.079 mm 0.0013-0.0031 in
    • 2nd Compression 0.033-0.079 mm 0.0013-0.0031 in
    • Oil Control 0.023-0.201 mm 0.0009-0.0079 in
    Piston Ring Width
    • Top Compression 1.176-1.197 mm 0.0463-0.0471 in
    • 2nd Compression 1.476-1.497 mm 0.0581-0.0589 in
    • Oil Control 1.854-2.007 mm 0.073-0.079 in
    Piston Pin (VIN K)
    • Diameter 21.9950-22.0000 mm 0.8659-0.8661 in
    • Clearance in Piston 0.0020-0.0130 mm 0.00008-0.00051 in
    • Fit-In-Rod (Clearance) 0.0066-0.0217 mm 0.0003-0.0009 in
    Piston Pin (VIN 1)
    • Diameter 22.995-23.0000 mm 0.90531-0.90551 in
    • Clearance in Piston 0.0065-0.0155 mm 0.00061-0.00026 in
    • Fit-In-Rod (Clearance) 0.0073-0.0225 mm 0.00029-0.00089 in
    Crankshaft
    • Main Journal Diameter-All 63.470-63.495 mm 2.4988-2.4998 in
    • Rod Journal Diameter-All 57.1170-57.1475 mm 2.2487-2.2499 in
    • Main Journal Taper-Maximum 0.00889 mm 0.00035 in
    • Rod Journal Taper-Maximum 0.00889 mm 0.00035 in
    • Main Journal Out-of-Round-Maximum 0.00635 mm 0.00025 in
    • Rod Journal Out-of-Round-Maximum 0.00508 mm 0.00020 in
    • Main Bearing to Journal Clearance 1 0.0178-0.0406 mm 0.0007-0.0016 in
    • Main Bearing to Journal Clearance 2, 3 and 4 0.0229-0.0457 mm 0.0009-0.0018 in
    • Rod Bearing Clearance 0.0127-0.0660 mm 0.0005-0.0026 in
    • Crankshaft End Play 0.076-0.276 mm 0.003-0.011 in
    Connecting Rod
    • Rod Side Clearance 0.102-0.508 mm 0.004-0.0200 in
    • Connecting Rod Large End Bore ID 60.295-60.312 mm 2.37378-2.3745 in
    Camshaft
    • Journal Diameter 47.655-46.858 mm 1.8462-1.8448 in
    • Bearing Inside Diameter 1 and 4 46.970-46.934 mm 1.8428-1.8492 in
    • Bearing Inside Diameter 2 and 3 46.977-46.942 mm 1.8481-1.8495 in
    • Bearing-to-Journal Clearance 0.041-0.119 mm 0.0016-0.0047 in
    • Intake Maximum Lobe Lift 6.56 mm 0.258 in
    • Exhaust Maximum Lobe Lift 6.56 mm 0.258 in
    Balance Shaft
    • End Play 0.0-0.171 mm 0.0-0.0067 in
    • Rear Journal Diameter 38.085-38.105 mm 1.4994-1.5002 in
    • Radial Play-Front, Bearing Clearance 0.0-0.026 mm 0.0-0.0010 in
    • Rear Bearing to Journal Clearance 0.012-0.109 mm 0.0005-0.0043 in
    • Drive Gear Lash 0.050-0.125 mm 0.002-0.0049 in
    • Bearing Bore Diameter-Front 51.973-51.999 mm 2.0462-2.0472 in
    • Bearing Bore Diameter-Rear, In Block 47.584-47.612 mm 1.8735-1.8745 in
    • Bearing Inside Diameter-Rear 38.118-38.194 mm 1.5007-1.5037 in
    Valve System
    • Lifter Hydraulic Roller
    • Rocker Arm Ratio 1.66:1
    • Face Angle 46 degrees
    • Seat Angle 45 degrees
    • Minimum Margin 0.635 mm 0.025 in
    • Seat Runout-Maximum 0.050 mm 0.002 in
    • Seat Width-Intake 1.53-2.03 mm 0.060-0.080 in
    • Seat Width-Exhaust 2.29-2.79 mm 0.090-0.110 in
    • Stem Height-All 49.15-50.17 mm 1.93-1.975 in
    • Stem Clearance-Intake 0.031-0.071 mm 0.0012-0.0028 in
    • Stem Clearance-Exhaust 0.036-0.074 mm 0.0014-0.0029 in
    Valve Spring
    • Free Length 49.78 mm 1.960 in
    • Load-Closed 334 N @
    43.69 mm 75 lb @ 1.72 in
    • Load-Open 1014 N @ 32.4 mm 228 lb @ 1.277 in
    • Installed Height 42.93-44.45 mm 1.690-1.750 in
    • Approximate Number of Active Coils 4.48
    • Approximate Number of Total Coils 6.60
    Flywheel
    • Runout-Maximum 0.38 mm 0.015 in
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  2. #2 Re: L67 Mechanical Specs
    GT Level Member TurboKent's Avatar
    Woodward, OK
    very nice!! where did you find such a thing?
    2003 Grand Prix turbo intercooled
  3. #3 Re: L67 Mechanical Specs
    Odessa, MO
    Quote Originally Posted by TurboKent View Post
    Shannon is what we sometimes refer to as an "idiot savant". LOL! He probably typed it from memory.
  4. #4 Re: L67 Mechanical Specs
    Quote Originally Posted by Abrasive View Post
    Hey - I resemble that remark! Wait....
    Actually, I got it from a friend of a friend and found it when I was organizing some of my files from my rebuild last year...for a new one upcoming.
    -Swash
  5. #5 Re: L67 Mechanical Specs
    Oklahoma
    Hmmm, I guess I just never got the savant part...
  6. #6 Re: L67 Mechanical Specs
    Just remember - I still have 7+ months to plot your demise...
    -Swash
  7. #7 Re: L67 Mechanical Specs
    Oklahoma
    Bring it baby!!!!
  8. #8 Re: L67 Mechanical Specs
    Oklahoma
    Oh, and not to diminish your efforts, but if you want the specs in document form, you can find them here:
    http://www.grandprixforums.net/f71/g...ject-9519.html
  9. #9 Re: L67 Mechanical Specs
    Jacksonville, Fl
    Good info. Sticky?
  10. #10 Re: L67 Mechanical Specs
  11. #11 Re: L67 Mechanical Specs
    1.66 again?
  12. #12 Re: L67 Mechanical Specs
    Omaha, NE
    1.66 again?
    Its in the mechanical specs, it has to be true!
  1. Cam specs?
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2017, 09:18 PM
  2. torque specs LIM
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 11-11-2008, 08:31 PM
  3. i need torque specs
    By MTXGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-20-2008, 12:14 PM
  4. Looking For Some Torque Specs.
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 07-10-2008, 02:58 PM
  5. need torque specs for...
    Last Post: 04-17-2008, 12:16 AM
