Thread: Custom Headlights (How to)
Results 1 to 15 of 15
  1. #1 Custom Headlights (How to)
    Banned
    Sioux Falls, SD
    I AM NOT RESPONSIBLE FOR ANY OF YOUR MISTAKES THIS IS AT YOUR OWN RISK
    1. Pre-heat oven to 200 degrees
    2. Take all rubber, headlights, wires off of headlight.
    3. Put headlights on a cookies tray that is upside down in the oven
    4. Bake for a bout 15-20 Minutes. Don't be afraid it will not wreck or warp your headlights
    5. You will know when they are warm enough to take them apart.
    6. Use to screwdrivers to pry the lense off the headlight. BE CAREFUL NOT TO SCRATCH.
    7. Repeat for second headlight.
    8. You will want to sand the black plastic insert so the paint has something to bons to. You will also want to use a plastic bonding primer. (I did not do anything of this due to the fact i had my body shop do it and they had special stuff lol )
    9. You can get your paint that matches your body from any GM dealer. ( I work at one so if u need the paint code i can get you it at no cost)
    10. The orange corners you can tint if you would like with VHT Nightshade. I tinted mine pretty dark but looks amazing! After they set up a little bit throw them in the oven at 170 to cure tha paint and bake it on for about 5 min.
    11. Clean off the old adhesive, you dont need to take it all off just cut it down so the new stuff can adhear. clean the areas where the adhesive will come in contact with, with rubbing alchool.
    12. Make sure your headlights are clean of all finger prints on the inside.
    13. I used urathane adhesive (like they use on windsheilds) to reseal the headlight. I let that sit overnight with some sort of clamps to keep pressure on it.
    14. Put all the accesories back on the headlight, and reinstall on your car
    15. Sit back and enjoy a custom look on your car
    Use this link for photos, http://www.flickr.com/photos/51132938@N05/
    Any questions please ask.
  2. #2 Re: Custom Headlights (How to)
  3. #3 Re: Custom Headlights (How to)
    Banned
    Sioux Falls, SD
    Can you sticky it??
  4. #4 Re: Custom Headlights (How to)
    memphis
    you might wanna put a disclaimer @ tha begining so to keep folks from b*^chin @ you if they screw somthing up..just a heads up..
  5. #5 Re: Custom Headlights (How to)
    Banned
    Sioux Falls, SD
    Good Idea thanks!!!
  6. #6 Re: Custom Headlights (How to)
    SE Level Member Lacboi's Avatar
    Jun 2010
    Atlanta
    and to help before damage occurs. do not bake for 20 mins, all you need to do is preheat to 250 and and when the light goes off(oven gets to temp) turn the oven off and then place lights in the oven for 5 mins. the uv coating will come off if you leave them in the oven with the heat element going. and the sealant can be reused or you'll have to get some taillight buthyl from the nissan dealership(its cheap and you can do a few cars with it) ill post pn if i find it.......
  7. #7 Re: Custom Headlights (How to)
    Pennsylvania
    I'll take up issue with step 5... and maybe 3
    5: I will know when they're warm enough? How will I know? Touch, smell, taste, clairvoyance?
    3: Why does the cookies tray have to be upside down?
    Also, I'd say fix the wrong words so you sound smart. You are giving instructions on how to modify a fairly expensive part; hard to trust instructions if you don't sound smart. Ex: to=two, bons=bond, tha=the, adhear=adhere...
  8. #8 Re: Custom Headlights (How to)
    Banned
    Sioux Falls, SD
    Touch and if the glue is loose enough to get the lens off, and cookie sheet if it has lips so it would be flat. And sorry somtimes i cant type. And i didnt have any problems with the temp being at 200 with constant heat.
  9. #9 Re: Custom Headlights (How to)
    Jun 2010
    Atlanta
    ^^^ well consider yourself lucky. and good write-up btw. and upside down keeps buthyl from getting on your cookies lol.
    and heres the link to the sealant
    MyNismo.com - NISSAN OEM Sealer
  10. #10 Re: Custom Headlights (How to)
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    Those look amazing! Nice job.
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  11. #11 Re: Custom Headlights (How to)
    Jul 2008
    sumter,south carolina
    Quote Originally Posted by alkygto View Post
    X2
    02 GTP with mods 05 GP for DD
  12. #12 Re: Custom Headlights (How to)
    Banned
    Sioux Falls, SD
    TTT
  13. #13 Re: Custom Headlights (How to)
    Pennsylvania
    ...did you just seriously bump your own tutorial?
  14. #14 Re: Custom Headlights (How to)
    You dont really do that....
    Theres no need.
  15. #15 Re: Custom Headlights (How to)
    Banned
    Sioux Falls, SD
    I did it for a guy that could not find it, sorry
  1. Custom Headlights
    By MidnightBlue in forum Visual/Body Modifications
    Last Post: 06-17-2010, 01:15 AM
  2. Custom Halo's in non-projector headlights?
    By chamilton89 in forum Visual/Body Modifications
    Last Post: 05-04-2010, 01:38 PM
  3. custom projector headlights.
    By 99gpse in forum Visual/Body Modifications
    Last Post: 11-21-2009, 01:22 AM
