Thread: 05 gtp swap into 03 mc ss start and stall
Results 1 to 6 of 6
  1. #1 05 gtp swap into 03 mc ss start and stall
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    Just finished the swap....2005 gtp entire front end swap in 03 mc ss .. Problem us it starts and last for about 4 seconds and die... If I plug maf up it dies in one second...... Another thing it revs up to 3k when it does crank..... I have good fuel pressure good spark new iac new map... all vac hoses are new and hooked up fpr is not wet around nipple....
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  2. #2 Re: 05 gtp swap into 03 mc ss start and stall
    Dec 2012
    Where 4T65E's were born
    Check the transmission harness. It may be unplugged in one of a few areas. Or you have a vacuum leak.
    Sold.
  3. #3 Re: 05 gtp swap into 03 mc ss start and stall
    brunswick
    all are hooked up and in good standing
  4. #4 Re: 05 gtp swap into 03 mc ss start and stall
    Hope your using the GTP PCM not the monte carlo one
    Edit even that would not work because the pcm is going to need to match the vin. cant just plug a pcm in from a different car and it will run.
  5. #5 Re: 05 gtp swap into 03 mc ss start and stall
    brunswick
    i got the pcm out the monte tuned with gtp file written in it..
  6. #6 Re: 05 gtp swap into 03 mc ss start and stall
    See your other thread on the issue.
  1. Stall/No start problem
    By Orinackra in forum General Tech Discussion
    Last Post: 01-14-2013, 10:23 AM
  2. Stall at Start
    By ShadowSwept in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2012, 04:05 AM
  3. erratic idle, stall, one no start... NO CODES!! HELP
    By pur3vil in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-08-2010, 10:06 AM
  4. start; stall. replaced everything. it's baffling.
    By jessinator in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-02-2010, 04:52 PM
  5. Start and Stall
    By l3enner in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2009, 06:35 AM
