Thread: flaps or doors in heater/ac system
Results 1 to 5 of 5
  1. #1 flaps or doors in heater/ac system
    Feb 2016
    North Carolina
    On my 2002 GP I am noticing occasionally with AC on ,the driver side air output gets warm ,compared to the passenger side. If i cycle thru the air / heat /def. postion switch or interrupt the air flow in anyway it corrects the problem. Sometimes for days ,other times for mins.
    Is this "easy" to fix ,were are the flaps/doors ,can I lube them ?
    I been under the dash once to put a blower motor in . . . that worked ! That was 3 years ago, this flap / door thing just started to happen.
    Al
  2. #2 Re: flaps or doors in heater/ac system
    Feb 2016
    North Carolina
    I got this in the wrong place ,sorry !
    Al
  3. #3 Re: flaps or doors in heater/ac system
    Blend Door Actuator Replacement
    check the actuator is working. you can put your finger tip on the part that turns and then change temp to see if its moving.
    ac might need a recharge if the blend doors working.
  4. #4 Re: flaps or doors in heater/ac system
    Feb 2016
    North Carolina
    [QUOTE=Scottydoggs;1507327]Blend Door Actuator Replacement
    ******* Scottydoggs ,
    OK, where the doors located ? Do I need to take muscle ache meds before I crawl under the dash ,or are they easily located under the hood ???
    Al
  5. #5 Re: flaps or doors in heater/ac system
    driver side kinda sucks. it under the dash above the gas pedal area on the side of the hvac housing. if you take the plastic under the steering wheel off and then the metal panel, you can see it through the crack on the right side by the console. then reach under to it. flash light is a huge help.
    pass side take the glove box out, its on the left side, cant miss it, easy side.
  1. Mud flaps
    By Dee23 in forum General Grand Prix Discussion
    Last Post: 09-05-2014, 06:30 AM
  2. Mud Flaps
    By asite57 in forum General Tech Discussion
    Last Post: 11-03-2012, 01:09 PM
  3. Heater Core? Cooling System? HELP!
    By YMS1975 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-31-2012, 02:20 PM
  4. Flaps for GP GXP???
    By gannon83 in forum Shops and Community Heroes
    Last Post: 12-29-2011, 07:35 PM
