Thread: moog tie rod end
Results 1 to 2 of 2
  1. #1 moog tie rod end
    pa
    Hello, I have a 2007 grand prix and I am changing the outer tie rod end. the tie rod I took off did not have a washer under the nut, but the Moog replacement tie rod has a washer, do I use the washer? Thank you.
  2. #2 Re: moog tie rod end
    St. Louis
    You can as long as the torque on the nut is correct and you can still get the cotter pin through it.
  1. Moog
    By hollilynn in forum General Grand Prix Discussion
    Last Post: 02-03-2014, 10:54 PM
  2. Which MOOG LCA?
    By FordMan77 in forum Brakes/Suspension/Chassis
    Last Post: 03-31-2013, 06:26 PM
  3. Moog Control arms just came in
    By walkac3 in forum Brakes/Suspension/Chassis
    Last Post: 02-26-2013, 02:23 PM
  4. Moog strut assy?
    By Wadeb79 in forum Brakes/Suspension/Chassis
    Last Post: 10-02-2012, 09:00 PM
  5. MOOG Sway Bar end links
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2010, 06:24 PM
