Thread: MOOG Sway Bar end links
Results 1 to 6 of 6
  1. #1 MOOG Sway Bar end links
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    How do u install them? they really arent that straight forward and dont come with directions. Help would appreciated thanks.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  2. #2 Re: MOOG Sway Bar end links
    front's or rears?
    Front's remove old. Put on new bolt, washer, rubber, control arm, rubber, washer, spacer, washer, rubber, sway, rubber, washer, nut
    Rears remove old. Put in place and tighten nuts.
  3. #3 Re: MOOG Sway Bar end links
    but on the 4 rubber bushings they hve a raised part on one end and flush on the other side. does that make sense?
  4. #4 Re: MOOG Sway Bar end links
    Charles City, IA
    raised parts goes opposite of the washer.
    SMGPFC Two Nipple General
  5. #5 Re: MOOG Sway Bar end links
    Honestly when I was posting I was laughing because your post wasn't really straightforward about which ones you were replacing. lol
    The raised part as mentioned is away from the washer.
  6. #6 Re: MOOG Sway Bar end links
    Charles City, IA
    Yeah the rears are a little different.
  1. links
    By 96gpse in forum General Tech Discussion
    Last Post: 07-03-2010, 10:17 PM
  2. 08 Grand Prix Sway Links
    By cbrown032008 in forum Introductions/Noob Questions
    Last Post: 10-07-2009, 06:33 PM
  3. Sway Bar End Links Question
    By GPBoy00 in forum Brakes/Suspension/Chassis
    Last Post: 03-18-2009, 03:19 PM
  4. i Need Links
    By gpracing in forum General Tech Discussion
    Last Post: 10-03-2008, 08:54 AM
