Thread: Cruise Control not working
Results 1 to 12 of 12
frankfiller Cruise Control not working 10-06-2015, 04:12 PM
Scottydoggs Re: Cruise Control not working 10-06-2015, 04:24 PM
frankfiller Re: Cruise Control not working 10-06-2015, 07:48 PM
frankfiller Re: Cruise Control not working 10-07-2015, 01:02 PM
BillBoost37 Re: Cruise Control not working 10-07-2015, 01:29 PM
frankfiller Re: Cruise Control not working 10-08-2015, 08:43 PM
BillBoost37 Re: Cruise Control not working 10-09-2015, 07:13 AM
frankfiller Re: Cruise Control not working 10-10-2015, 08:24 AM
frankfiller Re: Cruise Control not working 10-21-2015, 05:20 PM
ericspecullaas Re: Cruise Control not working 10-21-2015, 05:22 PM
born2pdl Re: Cruise Control not working 11-04-2015, 12:58 PM
frankfiller Re: Cruise Control not working 11-05-2015, 10:00 AM
  1. #1 Cruise Control not working
    Sep 2015
    Ohio
    The cruise control on my 04 grand prix isn't working. I took out the cc switch to test it with a multimeter. Does anyone know what values I should be getting, with the power button pressed in I get 8.25 kOhms which doesn't seem right.
  2. #2 Re: Cruise Control not working
    check if the third brake light bulbs are dead, if they are out replace them cc should then work.
  3. #3 Re: Cruise Control not working
    Sep 2015
    Ohio
    Sorry I should have mentioned that the lights are working. Plus i found out the cc switch has three resistors in it and one is 8.25 kohms, and the pink wire that leads to the switch gives 12V with the key on.
  4. #4 Re: Cruise Control not working
    Sep 2015
    Ohio
    It seems like my switch isn't very responsive because I can get it to work it just takes a couple attempts.
  5. #5 Re: Cruise Control not working
    Search on a guy named Highoctaneracing, I believe Kyle had this same issue and it should be pretty well documented.
  6. #6 Re: Cruise Control not working
    Sep 2015
    Ohio
    http://www.instructables.com/id/How-...n-04-Pontiac-/
    Is this what you're talking about? I have already removed the switch before, I ended up taking the steering off to see what I was doing. Thanks though.
  7. #7 Re: Cruise Control not working
    No.. I suggested searching on a guy here on the forum named HighOctaneRacing. While that may be his instruction, it's not the troubleshooting he did on this forum to figure out what was wrong.
  8. #8 Re: Cruise Control not working
    Sep 2015
    Ohio
    I did, that's how I found that link... Maybe you could be a little more specific, is there any keyword I should search with his name?
  9. #9 Re: Cruise Control not working
    Sep 2015
    Ohio
    Well anyway, I ended up taking the switch out and cleaning the contacts with isopropyl alcohol and reapplied some dielectric grease. Works like a charm now
  10. #10 Re: Cruise Control not working
    Feb 2013
    37.295091, -121.930053
    nice and easy fix
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  11. #11 Re: Cruise Control not working
    Apr 2014
    Utah
    Did you clean the switch contacts out at the end of the stock, or down in the multi switch where it bolts on?
  12. #12 Re: Cruise Control not working
    Sep 2015
    Ohio
    I opened up the switch, there is a small pcb and a weird plastic block that makes contact with the pcb. I cleaned those up and reapplied dielectric grease.
  1. cruise control not working.
    By Greg84 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-03-2015, 05:46 PM
  2. cruise control not working and i need it back?
    By tyler sharp78 in forum General Tech Discussion
    Last Post: 06-14-2014, 01:26 PM
  3. Cruise control not working as well as hud!!
    By HughJhas in forum How To Write-Ups/Tech Tips
    Last Post: 03-24-2013, 12:04 PM
  4. Cruise Control Not Working
    By Curt7 in forum General Tech Discussion
    Last Post: 07-07-2011, 08:10 PM
  5. Why is my cruise control not working?
    By bronzegp in forum General Tech Discussion
    Last Post: 04-12-2011, 05:44 PM
