Thread: Are all 3800 cam gears the same, or different per engine type?
Results 1 to 12 of 12
  1. #1 Are all 3800 cam gears the same, or different per engine type?
    Mar 2015
    Connecticut
    E.g. can you use a timing chain set (including gear) from an L26 on an L67, or other similar combinations, or will that throw the cam timing off?
    I think the chain is probably the same, but I'm coming up with different part numbers for the cam gears. I've read a few posts on various forums that seem to indicate they're not timed exactly the same.
  2. #2 Re: Are all 3800 cam gears the same, or different per engine type?
    I could have swore the cam timing was in the actual cam itself from the na to sc engines. If you order the timing kits off ZZP and Intense there is no na or sc specific application.
  3. #3 Re: Are all 3800 cam gears the same, or different per engine type?
    Mar 2015
    Connecticut
    Quote Originally Posted by Itchy2500 View Post
    I looked up parts on gmpartsdirect.com at four different Grand Prixs. Here's what I found.
    All timing chains had the same part number (24504668) as I expected.
    For the cam gear:
    '01 GTP (L67) and '06 GT (L32?) part 24505393
    '01 base (L36?) and '06 base (L26?) part 24505306
    So supercharged and NA have different part numbers for the cam gear, but L67/L32 are the same and L36/L26 are the same.
    What difference there is I don't know, but I'm guessing it affects cam advance/retard as I've read on a few forums. Does anybody know for sure?
    The Rollmaster is adjustable. I didn't find any non-adjustable cam gears on ZZP.
  4. #4 Re: Are all 3800 cam gears the same, or different per engine type?
    I've had so many of these in my hands over the years, never looked to see if the dot is a little different.
    Where's James when you need trivial knowledge? James.. oh 400TurbochargedSBC, come fill us in buddy.
  5. #5 Re: Are all 3800 cam gears the same, or different per engine type?
    hangover park IL
    SC (triangle Windows iirc) are 2* retarded at the keyway over the NA (round holes).
    Both are PM "forgings"
    ~James~ Psychotic Gearhead
  6. #6 Re: Are all 3800 cam gears the same, or different per engine type?
    Buffalo
    So If I have a timing gear from a l26 and one from a l67, they would look and work identical but the dot is in a different location on the gear ?
  7. #7 Re: Are all 3800 cam gears the same, or different per engine type?
    Mar 2015
    Connecticut
    Quote Originally Posted by Turbocharged400sbc View Post
    Thanks! Good info.
    So if you used a cam gear from an L26 on an L67 (with the stock L67 cam) it would advance the cam 2 degrees over stock...
    And an L67 cam gear on an L26 (with stock L26 cam) would retard the cam 2 degrees from stock...
    Not that you would necessarily do that, I'd think you would get an adjustible if you wanted to fine tune cam advance/retard.
  8. #8 Re: Are all 3800 cam gears the same, or different per engine type?
    Buffalo
    Here is an l26 set I want to use on a l67 because it's brand new
  9. #9 Re: Are all 3800 cam gears the same, or different per engine type?
    hangover park IL
    the. And the teeth are in the same position the keyway at the center that holds the camshaft in alignment is 2 degrees retarded on the supercharged setup this move the powerband up to reduce the customer complaints of burnouts in the rain from excessive low end torque
  10. #10 Re: Are all 3800 cam gears the same, or different per engine type?
    Mar 2015
    Connecticut
    ...to reduce the customer complaints of burnouts in the rain from excessive low end torque
  11. #11 Re: Are all 3800 cam gears the same, or different per engine type?
    hangover park IL
    Dont laugh... its how the tc n abs integration became part of the NVH solutions....
  12. #12 Re: Are all 3800 cam gears the same, or different per engine type?
    hangover park IL
    Gm learned loads from the tall deck SI buicks. ...na and SC ....obd2 let em control things better
  1. Bearing Type sound at 5-10 mph, misfire type feeling 40-50mph turning right
    By crapshoot in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-15-2014, 02:13 PM
  2. video of engine switching gears,look right?
    By spider4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-23-2011, 02:57 PM
  3. engine swap 3800 sc to same but not burned engine
    By roger7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 01:59 PM
  4. rattling from engine/bad ideling/gears slip when going up hills sometimes
    By jordonr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-07-2010, 02:53 AM
  5. 3800 sc engine
    By Brandon Busenitz in forum Engine
    Last Post: 04-13-2010, 02:37 PM
