I just got my resonator replace about a month ago and just notice where they added the joint sealer the back end of it came off, in the result there is a small leak where the two joints meant. I tried this product http://www.canadiantire.ca/en/pdp/ve...l#.VfFi6fA7eis twice with no success. First time applied I waited about 6hrs and the stuff came right off, second time applied I waited 24hrs and the stuff came off. The garage used a rubberize stuff that tends to hold better this stuff I use it dries and turns solid. Either I need a silicon base stuff or I remove the clamp that is holding the other half and put the muffler tap around the joint. Can anybody recommend something that will work and that dries soft and not get hard.
Thanks
