Thread: Bogging under boost
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: Bogging under boost
    Kemmerer, Wyoming
    Quote Originally Posted by Regalgse00 View Post
    Ok. So I have taken off the belt and I can give her hell. I already disabled the Bbv and plugged the vac line to it and still no change. I have tr6 plugs 55 gap. I have a 3.2 on it now. But will do it with any pulley size. I used to have a adjustable fpr and got rid of that and got a stock one so I can still use my AN fittings. The intercooler I got was from sseilmnop. One of his recent ones. And it didn't have the holes for the pcv. So I tapped my valve covers and ran a catch can
    if the intercooler you got from sseilmnop was a newer one, it would have the pcv holes in it.
  2. #22 Re: Bogging under boost
    Feb 2014
    Milwaukee
    Well just set up how the vacume lines would be for stock. Tomorrow I'm going to take out my fuel pump and check that plastic venturi hose and replace if with a rubber hose. I emailed zzp just to see what they would say and they said it sounded fuel related. And they had a gtp with similar issues cause the cup was going empty starving it. So I'll just double check.
  3. #23 Re: Bogging under boost
    Feb 2014
    Milwaukee
    And the intercooler does not have the holes
  4. #24 Re: Bogging under boost
    every pic ive seen of his ic's have holes for a functioning pcv. i find it hard to believe it dont have them.
  5. #25 Re: Bogging under boost
    Feb 2014
    Milwaukee
    I'm postive I have no Pcv holes in it. If I could upload this pic I'd prove it. But I no for a fact it doesn't
  1. Car bogging when I boost
    By GrandPrixgtp2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2016, 08:54 PM
  2. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  3. half boost and bogging
    By undecided in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2011, 10:50 AM
