Thread: Car Burns Oil Upon Starting Occassionally
Results 1 to 20 of 21
  1. #1 Car Burns Oil Upon Starting Occassionally
    Sep 2012
    Las Vegas
    Hello again everybody. Long time no post.
    I had a slight water leak from the corner of the lower intake manifold on my 97 Grand Prix 3800 with 156K miles, and had the manifold gasket replaced and also installed a new upper intake manifold and gasket set. This fixed the water problem, but about a week later noticed a cloud of white smoke coming from the exhaust pipe upon starting the car for the first time of the day. The smoke quickly dissipates and doesn't smoke after the engine is running. It only smokes on about 1 out of 10 starts.
    My question is: Could this be caused by something involving the manifold gasket change or is it a coincidence? I am thinking that with the smoke occurring only on start-up, could it be the valve stem seals? If it is the seals, can they be replaced without removing the heads?
    Will appreciate any and all thoughts on this matter. Thank you.
  2. #2 Re: Car Burns Oil Upon Starting Occassionally
    Feb 2013
    37.295091, -121.930053
    well first off dont beat your car. second these cars do burn more oil than you think. thirdly im thinking that your valve guides maybe going that a real good sign for them going
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Car Burns Oil Upon Starting Occassionally
    Jul 2010
    Coquitlam,BC,Canada
    If the smoke is white, then you have a coolant leak.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: Car Burns Oil Upon Starting Occassionally
    Buffalo
    Worn valve seals or even a lifted seal. The oil seeps past them while sitting Turn on the csr and you quickly burn off the build up.
    I had had one valve seal lift on the exhaust valve. It would smoke at idle and even worse if I was on an incline (rear head)
  5. #5 Re: Car Burns Oil Upon Starting Occassionally
    Buffalo
    X2 on the color of the smoke
  6. #6 Re: Car Burns Oil Upon Starting Occassionally
    Jul 2010
    Coquitlam,BC,Canada
    Valve seals would be blue smoke.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: Car Burns Oil Upon Starting Occassionally
    St. Louis
    So your car is a social smoker, eh? White smoke is usually coolant. Have you check to see if the coolant level is dropping at all? If you just had the LIM/UIM gaskets done then maybe one of them didn't set right and is leaking a bit, or the UIM is cracked somewhere if you are N/A.
  8. #8 Re: Car Burns Oil Upon Starting Occassionally
    Buffalo
    Quote Originally Posted by Bronco Boy View Post
    OP's title said "burns oil"
  9. #9 Re: Car Burns Oil Upon Starting Occassionally
    SWPA
    I think you guys are overthinking this. He says it only smokes on the first start up of the day. My guess leans more toward normal condensation and it not being smoke at all.
  10. #10 Re: Car Burns Oil Upon Starting Occassionally
    Buffalo
    Yup. Had this thread before too lol
  11. #11 Re: Car Burns Oil Upon Starting Occassionally
    Nov 2013
    Wisconsin!
    Quote Originally Posted by SallyBabe03 View Post
    Except if it's white smoke like he says. It's not oil whether he thinks it is or not.
  12. #12 Re: Car Burns Oil Upon Starting Occassionally
    Buffalo
    Lol who cares. If it's an oil leak then refer to my post. If not , then refer to the other post lmao!
  13. #13 Re: Car Burns Oil Upon Starting Occassionally
    Nov 2013
    Wisconsin!
    It matters. Since a valve seal will smoke every time all the time. So if he is just noticing condensation then it's nothing. If he actually has an oil or water leak somewhere then there is still a problem.
  14. #14 Re: Car Burns Oil Upon Starting Occassionally
    Sep 2012
    Las Vegas
    The smoke is white, but it smells exactly like burned oil.
  15. #15 Re: Car Burns Oil Upon Starting Occassionally
    Sep 2012
    Las Vegas
    The upper intake manifold is brand new, plus the coolant level is still full.
  16. #16 Re: Car Burns Oil Upon Starting Occassionally
    Sep 2012
    Las Vegas
    I'll have the cooling system pressure tested to check for leaks and a compression test of the cylinders.
    Thak you too all who offered dome advice.
  17. #17 Re: Car Burns Oil Upon Starting Occassionally
    Buffalo
    Quote Originally Posted by koRnhead View Post
    it must really bother you
    and FWIW i listed my example for an example. You lift a seal and report back
  18. #18 Re: Car Burns Oil Upon Starting Occassionally
    Nov 2013
    Wisconsin!
    Been there done that in my Galant VR-4 years ago. No people like you dismissing what's going on in this guy's car bothers me. He came here looking for help. And you give nothing. Since it's clearly not a valve seal issue.
  19. #19 Re: Car Burns Oil Upon Starting Occassionally
    Buffalo
    I never dismissed what is going on.
  20. #20 Re: Car Burns Oil Upon Starting Occassionally
    Sep 2012
    Las Vegas
    Oops! I meant to say 'some' advice not 'dome' advise. Didn't mean to imply anything. Thanks anyway.
  1. REPAIR cigarette burns
    By smitz327 in forum Detailing Tips and Tricks
    Last Post: 05-08-2013, 09:32 AM
  2. car occassionally dies on startup
    By FX4 Level II in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-02-2012, 10:37 AM
  3. Need Help Please with not starting
    By flaspeeder in forum General Tech Discussion
    Last Post: 10-24-2011, 04:13 PM
  4. Just Starting!
    By fpgt17 in forum Introductions/Noob Questions
    Last Post: 01-17-2011, 01:01 PM
  5. Replies: 6
    Last Post: 05-30-2010, 03:30 PM
