Thread: Shift Lock Stuck Until Car Warms Up
Results 1 to 5 of 5
  1. #1 Shift Lock Stuck Until Car Warms Up
    Sep 2015
    Indiana
    I have a 2000 GTP. I have read the other post on this topic but it wasn't exactly the same problem.
    My car won't shift from park until it warms up a little. In the mornings when it is cold it takes 1-2 min and when I start the car in the middle of the day, when it's hot, it takes 0-30 seconds. I am thinking that it can't be a broken wire in the harness because, if it was, it wouldn't shift at all. I can't think of what would cause it to begin working after the car warms up a little. Any thoughts?
  2. #2 Re: Shift Lock Stuck Until Car Warms Up
    most of the time its bad wires, so its worth it to look in the console.
  3. #3 Re: Shift Lock Stuck Until Car Warms Up
    make sure your brake lights work too. iirc i saw a post that the guy needed a brake switch to fix both issues.
  4. #4 Re: Shift Lock Stuck Until Car Warms Up
    Jan 1970
    Maquoketa, Iowa
    Check ball in the trans lines?
  5. #5 Re: Shift Lock Stuck Until Car Warms Up
    When you say won't shift. Do you mean the shifter physically won't move or when you put it in year the transmission doesn't engage and allow you to move the car until it warms up?
  1. Key stuck in ignition lock cylinder
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 01-17-2019, 10:47 AM
  2. Shift lock fix
    By Iceman6669 in forum General Tech Discussion
    Last Post: 02-11-2014, 05:25 AM
  3. Replies: 1
    Last Post: 12-08-2012, 07:39 PM
  4. Stuck In Park. Shift Lock Release Doesnt Work.
    By SilverGT in forum General Tech Discussion
    Last Post: 07-24-2012, 01:23 PM
  5. sHift lock
    By 97gmgtp in forum General Tech Discussion
    Last Post: 12-18-2010, 01:19 PM
