Thread: Does getting straight pipes throw back an error code?
Results 1 to 17 of 17
  1. #1 Does getting straight pipes throw back an error code?
    May 2015
    Maryland
    Does getting straight pipes throw back any error codes that may prevent the car from passing emissions?
    Matt
  2. #2 Re: Does getting straight pipes throw back an error code?
    IF you removed the cat converter, yes.
    Otherwise removing the just the mufflers, no. It will sound like pure butthole though, you will hate the sound unless you like to sound like a honda with a fart cannon on it.
  3. #3 Re: Does getting straight pipes throw back an error code?
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    So people who remove their cat, how do they get around tripping a code?
  4. #4 Re: Does getting straight pipes throw back an error code?
    Jan 2014
    AR
    I use an 02 emulator. On a 99 model. But I use a hi-flow cat.
  5. #5 Re: Does getting straight pipes throw back an error code?
    You can turn off the check engine light with a tuning software, 97-00 is a simple set to no report for the cat code P0420 and 01-03+ cars can try the non fouler trick aswell as turning off the code to stop the cat diag test from going on. I think DHP tuners can turn it off though. Or the o2 emulator for 97-00 cars.
  6. #6 Re: Does getting straight pipes throw back an error code?
    May 2015
    Maryland
    This is what I'd like it to sound like:
    https://m.youtube.com/watch?v=RYIiBQnv978
    Doesn't sound like a fart cannon to me. lol
    Matt
  7. #7 Re: Does getting straight pipes throw back an error code?
    Quote Originally Posted by Bloodpython171 View Post
    Whoever edited that video did a very very bad job, blur the drivers tail light instead of the plate? He was a few frames behind on blurring out peoples faces quite a few times, then gave up later on in the vid lol.
  8. #8 Re: Does getting straight pipes throw back an error code?
    is yours a v8? or v6? either one you'll get pulled over for being to loud, then your ears will bleed after a week, or less. its horrid sounding in real life.
    last guy i said this to was all taken back and pissed that id suggest he'd get a ticket even, then guess what? he got a ticket, then his ears hurt, mufflers back on.........
  9. #9 Re: Does getting straight pipes throw back an error code?
    May 2015
    Maryland
    Matt
  10. #10 Re: Does getting straight pipes throw back an error code?
    May 2015
    Maryland
    I don't know why my signature pic isn't showing up but I own a 2006 GXP.
    Matt
  11. #11 Re: Does getting straight pipes throw back an error code?
    May 2015
    Maryland
    *test*
    Matt
  12. #12 Re: Does getting straight pipes throw back an error code?
    Well since it's a V8 it will sound good at idle and might be a little loud while driving but the only biggest thing you might not like is when it switches in and out of the DoD. Going down into V4 mode can make it sound bad but that is going to be up to you.
  13. #13 Re: Does getting straight pipes throw back an error code?
    3 words, "dont do it" get a cut out if you want it loud.
    dirtdog has one on his gxp. look him up.
  14. #14 Re: Does getting straight pipes throw back an error code?
    May 2015
    Maryland
    I'll check him out but don't like the idea of it coming from the sides of the car.
    Matt
  15. #15 Re: Does getting straight pipes throw back an error code?
    If you want to go straight pipes I would do the DOD elimination mod. When that kicks in its supposed to sound kinda like a helicopter from what I have heard.
    If it was me, I would either get some Flowmaster 40 series mufflers put in place of the stockers, or put a glass pack in. It might still sound weird when the DOD kicks in and out though.
  16. #16 Re: Does getting straight pipes throw back an error code?
    May 2015
    Maryland
    Will this cause any error codes? Any other tips or helpful advice (besides don't do it) would be appreciated. Thanks for answering my other 2 questions DeathPunch.
    Matt
  17. #17 Re: Does getting straight pipes throw back an error code?
    As long as whatever it is you are taking out or replacing is after the cat you will never throw a code because there are not any sensors after the post cat O2.
  1. Dual valance & straight pipes
    By rafael802 in forum General Grand Prix Discussion
    Last Post: 06-25-2014, 06:07 PM
  2. Best Way to delete Straight pipes
    By Beelzeboul in forum General Tech Discussion
    Last Post: 08-26-2012, 09:18 PM
  3. Straight pipes sound bad, loud ticking when accelerating
    By 2000 Grand Prix GT Blue in forum General Tech Discussion
    Last Post: 04-12-2012, 12:05 AM
  4. Dual Straight Pipes
    By pontgp02 in forum General Tech Discussion
    Last Post: 07-18-2011, 11:10 AM
  5. Straight Pipes on GTP?
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2008, 08:12 PM
